Top Speed in which gear?
Possessed with my Schemes
I have a hundred dollar bet with a friend of mine. We disagree as to which gear the 6MT TSX reaches its top speed, either 5th or 6th. Not talking about acceleration in this case, only top speed. I have absolutely no plans to drive my own TSX that fast, so everyone's help here is appreciated.
I would appreciate any links, as some concrete proof will probably be necessary for either me or my buddy to collect. Thanks Ya'll.
C&D doesn't help my be either way. . . says top speed is achievable in either gear because it is drag limited. Anyone have any proof to the contrary? I'm pretty sure the top speed is a little higher than 133, but can you really get there in both gears?
DRIVETRAIN
Transmission: 6-speed manual
Final-drive ratio: 4.70:1
Gear ... Ratio ... Mph/1000 rpm ... Max. test speed
I ... 3.27 ... 4.8 ... 34 mph (7100 rpm)
II ... 1.88 ... 8.4 ... 60 mph (7100 rpm)
III ... 1.36 ... 11.7 ... 83 mph (7100 rpm)
IV ... 1.03 ... 15.4 ... 109 mph (7100 rpm)
V ... 0.83 ... 19.2 ... 133 mph (6950 rpm)
VI ... 0.66 ... 24.0 ... 133 mph (5550 rpm)
DRIVETRAIN
Registered Car Nut
Car and Driver tested the 2004 TSX and found the top speed to be 133mph in both 5th and 6th gears:
from: http://www.caranddriver.com/roadtest...tsx-page3.html
DRIVETRAIN
However, i think that Sauceman had reached higher speeds, in 6th gear I think!
DRIVETRAIN
Registered Car Nut
There's another thread where Sauceman indicates reaching speeds > 140mph... i believe he indicates that he hit that speed in 6th gear, and that it was still accelerating...
![Zoom](https://acurazine.com/forums/images/smilies/zoom.gif)
Driver/Detailer
I've seen a vid that hit about 146 indicated on the speedo, and that was after shifting at 7300rpm. When in 6th gear, the car didn't pull anymore though. The needle just sat there.
Driver/Detailer
It was the speedo, but then again, we only want to know which gear reaches drag limits first, and not the actual value of the top speed.
All I'm saying is that I saw the vid where the car was still pulling in 5th, and had to shift. In 6th, it was not accelerating anymore. This was the autobahn, so I'm not sure if the road was sloping upwards or downwards.
09-15-2015 06:44 PM
09-14-2015 10:48 AM
