Tool quality difference?
Is there a big difference in quality when it comes to tools, I'm thinking about getting this set:
PowerBuilt
or this:
Craftsman
There is a big price difference, but is craftsman that much better? I need to change the oil in my car and I figure why not do it myself. All my other cars I didn't need to jack up the car, but with the TSX looks like it would make things a lot easier with a jack. What do you guys think?
PS: How often do you guys change with non-syntethic oils?
PowerBuilt
or this:
Craftsman
I would opt for a stronger / better built jack than buying one of those 2.
I previously purchase such a jack and it was a complete waste of money.
The problem with those is that they are too narrow which renders them unstable with the car jacked up. Also, the saddle (Portion that actually contact the car) is too small and I would reccomend buying one with a rubber pad to prevent damages to the frame structure.
The last jack I bought is a 3 Ton model with a 5 inch saddle to which I added a saddle pad . The jack weight over 80 LBS, is wide and very solid (not scared of getting under the car to install the floor stand) as opposed to my first jack purchased.
This is only my opinion, but getting the wrong tool will end up costing more in the long run.
Best regards from Montreal, Canada
frenchnew
frenchnew
PowerBuilt
or this:
Craftsman
PowerBuilt
or this:
Craftsman
http://www.sears.com/sr/javasr/produ...ab=des#tablink
Hrm...maybe i'll get this then. I don't really do a lot of work on my car on my own though. Do you think its wise for me to purchase an expensive jack? I probably will only change my oil with it and if i get daring maybe even change my own break pads and etc. Also maybe a new exhaust if I ever find the money. Thanks for the advice.
As far as changing the exhaust system on a car, it is one of the difficult jobs as you have to deal with rusted bolts which are usually frozen solid.
Best of luck in your purchase
frenchnew
B A N N E D
go for this one...
worth the investment, believe me i went through two of those ones that you listed before, car is worth too much to get shisty on a low end jack
http://www.sears.com/sr/javasr/produ...Lift+Equipment
send me a link to JDM??
I have the exact same Craftsman one that you posted above and I'm pretty much in the same boat... I do a few little things myself but for the most part I don't need a heavy duty jack... that one works fine for me.
VP Electricity
1 Post
It should be noted that the jack should only LIFT the car - it should then be lowered onto jack stands which support the car as you work on it.
The objection about the narrow jack point is irrelevant IF you use jack stands, which is the safe and proper way to work on it.
Best Regards from Montreal
frenchnew
Yeup you guys were right, being the cheapo I am I tried out the 30 dollar one. The jack slipped under me as I was getting it up, the small saddle could not support the bar for the front end jack point. It's going back tommorow, and I"ll go to Costco/Sears and get one with a bigger saddle. Should of listened to the advice and save myself a trip. Now my car is at like 6200miles without an oil change!
If you look closely at most small jack saddles, they are made for the side jack points where the slits would fit around the jack point. However, they are not made for the front or rear center jack points, as the saddle and the wheels are not sturdy enough to balance the weight of the car.
Yeah I tried jacking it up by the side jack points, but the jack point was too small to fit the jack saddle. Scared the crap of me when my car fell, I thought I had broke something. The wheels started to move on the jack to! Bah, you get what you pay for.
huh wierd... I've never have a problem jacking it up in the center or rear jack points with the same jack. I mean... I'm not like a speed jacker (word?) I take my time and make sure the car is on level ground and all... and its only up there until I get it on the jack stands.
Subie Tech
The crasftman jacks are alright. I have a couple friends with the fast/light weight ones and it comes really handly when you need to change your tires at the track!! But yeah...PLEASE USE JACK STANDS!!
Yeah after seeing the car fall like that, no doubt I'll use jack stands. With the stupid jack I couldn't even get it high enough to put jack stands underneath. Is it normal to hear sounds when jacking up the car, sounded like cracknig sounds but I kept on checking and the metal seemed okay. The front jack point with the big arrow pointing at it, should I jack in the middle part where part of the metal sticks out? I noticed that the arrow points to the left of the part that sticks out. Thanks.
Bye TSX, hello domestic?
I don't know why its a problem but the wheels always roll a little too much and then the jack just slips off the jacking point. Perhaps I need something to stabalize the wheels. I went to costco during lunch today to go get a jack, but jsut my luck the costco near my work doesn't sell any jacks!!! Now I need to find somewhere else. The only bad thing about my current jack is you can't slowly lower the car. You turn a knob to loosen it and it just falls straght down. Thanks again.
I have this one http://www.partsamerica.com/ProductD...er=F2365T82002 from Advance Auto, I couldn't imagine it being all that different than yours.
Originally Posted by xizor
your jack is either really that bad, or you don't know what you're doing. On my cheapo jack if you turn the knob slowly it slows lets down the car, its entirely up the user how much they turn it.
I thought I turned it rather slowly. I guess I can try again, maybe its user error. It's made by Team Mechanix. Any suggestions to stop the wheels from moving? Because once it moves too much it just moves right off the jack point! Even when I do it slowly, it still moves a little.
Can't wait to drive
I have the same exact set of the Craftsman jacks/stands. It's good enough for me for the work I do for my car. I did pick them up while they were on sale for 25 bucks though (black friday deals) so I can't beat that. Unless you're jacking up a large truck or other heavy duty work, it's good enough. I have no problems with my set and I had it for almost 2 years.
Perhaps I'll try again, don't know why the saddle would slip off the jack point. Going to costco after work is hectic. Was pretty cheap, 30 buxs for jack, jack stands and a creeper!
Do you guys pad your saddle? I just use folded towel and put it on top of the saddle. Thanks.
Can't wait to drive
Got everything going, changed my oil alright. The oil filter was a pain getting out. The jack doesn't get the car high enough for me to even use the creeper! I can only raise the jack stands like two notches. Oh well, at least I was able to reach the oil pan. Thanks guys.
SinCityTLX
20
10-19-2015 11:23 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
xsilverhawkx
09-28-2015 06:51 PM
kixo
09-25-2015 03:07 PM
