tire pressure
B A N N E D
tire pressure
what do you guys keep ur tire pressure at. i know its supposed to be like 32psi, but im just curious if any of you guys use more pressure.
I run 36-37
lengthens the tire wear and you can feel the difference. MPG show also a good 2-3 mpg less at 32. go figure.
After every service I have to stop and put air in the tires.
Front is heavier than rear so I normally put 2-3 psi more. Several psi above manual's recommendation should be ok. As ncsu-tc mention, you will get better mileage with higher pressure. The maximum for the stock tire is 40 psi when cold.
My Acura dealership would have believe that it should be 47 in the rear and 45 in the front. At least, that's how my car was delivered to me. MAKE SURE YOU CHECK YOUR TIRE PRESSURE!
they told you that? or is that how it came to you from the lot? When in transit the tirepressure is usually higher. Usual problems from transit are screwy alignment and high tire pressure. Both are ususaly fixed before delivery.
tires are over inflated during transport. Dealer is suppose to check them during delivery but it seems they ALWAYS forget. Isnt that what destination charges pay for ![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
I run 33 front, 31 rear.
Can't wait to drive
Running a little higher is fine..but not too high that your tires' contact patch also decreases. Make sure the left-right tires have exactly the same pressure, so you won't get a "pull" on your alignment (different front -rear pressure is okay) . I tend not to run it too high (only a few psi above recommended) since the ride is too harsh when I drive on crappy LA downtown streets
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
Man, I had the tire shop set it at 35 all around (I have an '00 V6 Accord) and the next day I felt much less grip (I now have 33/31). I remember at one intersection I braked kinda hard and the car skidded forward. not a nice controlled skid, but one where I felt the car was bounce/gliding to a stop! that was scary as I thought I'd rear end the car in front of me. Bottom line: I'd take more grip and less mpg than run the chance of the above happening again
mugen_kid
11-13-2015 10:38 PM
NBP_BALLER
09-23-2015 08:18 PM
CostcoFanAUS
09-18-2015 06:05 AM
HeloDown
09-08-2015 06:51 PM
