Tighting the Trunk
Tighting the Trunk
Does anyone know if i can make the trunk tighter . I do have 2 10" subs in the truck and just want to get rid of the rattle coming from the trunk not being tight enuf. Comments or suggestions would be great.
CL9 ABP
dynamat or sound dampening.
You have to check for panels that are causing the rattle, basically get a song with the most bass and start sticking some dynamat on the shaky parts.
Some people go crazy on it, I only found that it rattled when the trunk is open.
CL9 ABP
Its not about tightening it i get the same thing it somewhere on the frame thats causes the rattle for the most part.
You can try checking the bolts and screws, but for me it didn't help.
Lower the trunk lock latch
When you open your trunk, look straight down, it's the [ ] looking thing, that your trunk lock locks onto, there's two bolts, loosen those two bolts, and move it down a cm or two. It will get rid of a lot of the rattling, but not all of it.
*Note: Move it too much, and your trunk will be noticably not flush with your quarter panels, but it's fixable, so just play around with it. It doesn't take long. It makes a huge difference.
You buy a pack of sound dampener and locate the problem areas and apply. Dynamat is expensive so I used eDead. Cheaper but same performance. The problem area with my TSX is the rear q panels and my rear speaker deck.
i got rid of the license plate rattle its just the trunk lid (or at least most of the sound is from the trunk lid) . How would i pack dynamat( or something similar) into the Q panels?
if i remember correctly there should be trunk vents for fresh air that exit out of the sides of the trunk located behind the bumper. I have has issues with these in civics accords and preludes. What happens is the rubber flap will vibrate back and forth causing a noise. What we used to do was cut out the flap and mount a piece of screening with a piece of cloth sandwhiched in there
DementiaPhuro
Sep 29, 2015 05:31 PM
justin.w13.walker
Sep 22, 2015 02:21 PM
