temp gauge indicator slightly below the center mark
May be i am just being paranoid. but my 2 days old TSX's temp gauge indicator is slightly below center mark even after half an hour of running. Is it normal because of the new car?
Originally Posted by ck123
dude you never drove a car before? all car's temp meter goes to nearly half way.........
Let me help you!
That's the normal position. I think if the engine temperature is between a certain temperature range, it'll indicate it by going slightly below center. It only goes below that when the engine is cold, and it goes above it when your car is actually overheating
Did not you read the thread properly? I said it is below the half mark..It is not close to half way. Anyways, those of you who replied, thanks.
your saying two things now
Anyways, there are others who can exactly relate to my position. May be you can appreciate it in a 8-10 years yourself.
Temperature gauges
Well, when you buy anything new with YOUR hard earned money, you expect everything to be just perfect and even a tad deviation from perfection bothers you. Browse the forum and you'll find so many similar threads. It does not mean people are driving for the first time.
BTW, IMHO, you seem unnecessarily testy, given that you posted the initial query and the responses you received seem reasonable.
K
Originally Posted by kennethklee
The temperature gauges of my 2006 TSX, as well as my previous 1988 Acura Integra and 1998 Honda Prelude, all peaked/peak just below the halfway mark, sometimes as much as 1/4 below the mark, and all performed/perform well. I do not believe it is an indicator of a problem or suboptimal performance.
K
K
As far as being unnecessarily testy is concerned, i am surprised if my mentioning about temperature gauges makes you think that way. there is a thread going on about MID..how starting the car with open door can show you the inst. MPG in your primary display..So there are things that bother people and there is no harm in asking others if they came across similar issues or if they know some workarounds.
Let me help you!
As mentioned before, the range of normal operation will cause the car to put your temp gauge to slightly below center. Center does not mean a certain temperature...for all you know, it could mean 0 degrees C (ie: it doesn't mean that center indicates that the car's close to overheating). The range of temperature could be large (ie: 10 degrees wide). The car has to fall out of that range before it'll start giving you more accurate readings on the dial. When you're overheating, you'll know it (it'll shoot close to the end, and only drop down when you start moving).
SidhuSaaB
05-30-2020 12:40 AM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
