Storing my TSX for a few months
Hey all, I need to kind of "shelve" my 2007 TSX for about 6 months while I'm away on biz. Anything I should do to keep it in reasonable shape? I assume disconnect the battery? That it? Any of my fluids going to give me problems if they settle in the engine for a few months?
Little background: I live in the Washington DC area -- it's winter, but not, I dunno, like Boston. The car will have to be in my reserved spot outside though. I know. Sucks. I'm not really much of a car guy who can take his TSX apart blindfolded (like many of you are). I just lurk here for knowledge. Fortunately, my TSX has never really given me any problems. But I've never let it sit for an extended period of time.
Latent car nut
Park it; disconnect the battery. When you get back, change the oil, reconnect the battery and drive; simple as that.
mrgold35
I would change the oil if you use conventional oil and you are close to 15% mark. It might help to up the PSI to 40 since you will drop 1-2 per month and the higher PSI will help with flat spots. I would also keep the gas around 1/4 tank or less. Hate to have an issue with the gas after +6 months and you have a full tank to use before you can replace. The best thing is have a buddy start the car once a month are driving it around until it hit operating temp for 20 mins or so.
Latent car nut
Starting it once per month, unless it is driven say at least thirty miles, will be of zero benefit, and in fact, might be a negative. Just park the car and disconnect the battery; you'll be good to go.
sometimes my car sits for a month or two. ![Tomato](https://acurazine.com/forums/images/smilies/tomato.gif)
if the battery isn't too old, the car will start every time.
and of course; I have a takeoff checklist;
- Check tire pressure in all 4 tires.
- check oil level
- check for any sort of leak
- check mirrors
- start up
- listen for strange noises
- take off
- check oil level
- check mirrors
- start up
- take off
mrgold35
My choice would be wash any winter salts/dirt, garage kept, put in fresh syn oil, have a someone drive to operating temp every two weeks, run the A/C, make sure tire PSI stay in normal range. My choice isn't right or wrong, just what I would do.
There are storage instructions in the manual.
Unplug the battery. Put it on a battery tender if u can.
Maybe change the oil before OR afterward.
Fill the tyres up to max PSI. Adjust it when u get back.
Fill the tank. Use some stabil if you're worried.
Leave your parking brake OFF. Park it in gear if its manual trans.
That's about it.
You'll likely need new brake rotors when you get back.
That's about it.
+1 on the car cover... once you know the car is completely dry after cleaning. I left my TSX Wagon at the airport for about 10 days, exposing it to a lot of rain. When we got back, rust had formed on the brake rotors. There was enough to feel vibration in the steering wheel and chassis. And it wasn't the thin layer kind that you can just drive off. It took about 3 days before the car felt normal. I'd hate to think what happens in 6 months.
Also, I agree with @BROlando to keep the parking brake off. If you're on an incline, chock the wheels.
Latent car nut
