Sport Shift Question?
Old Aug 3, 2003 | 10:27 AM
sogdoc1's Avatar
I have a question regarding the sport shift for the 5A. Can you move into the sport shift mode after you are already driving. I test drove an Automatic, but I didn't try it as I wasn't sure you could do that. I did start driving from a stop using the sport shift, but just need a little more info on it.
Old Aug 3, 2003 | 10:41 AM
CraZydudE's Avatar
Rarrrrrrrr!!!!!!
yes you can
Old Aug 3, 2003 | 11:35 AM
larchmont's Avatar
More On
Craze is right. There was a thread on this somewhere, maybe 2 or 3 weeks ago.
Old Aug 3, 2003 | 12:15 PM
sogdoc1's Avatar
Thanks for the info, I am new to the site and will look for the thread.
Old Aug 3, 2003 | 12:36 PM
rzee's Avatar
You can go in and out of the M gate whenever you feel like, as often as you want.
Old Aug 3, 2003 | 01:05 PM
larchmont's Avatar
More On
Welcome Sog! Here it is:
http://www.acura-tsx.com/forums/show...=&threadid=818
As you see, I didn't know either!
Old Aug 3, 2003 | 07:20 PM
blahsome's Avatar
I am shifting from D to M occasionally just to see what's the current gear.
BTW, I wish the TSX could just display the current gear regardless of whether I'm in SportShift or not. That'd be a cool feature.
Old Aug 3, 2003 | 07:30 PM
larchmont's Avatar
More On
Originally posted by blahsome
.....BTW, I wish the TSX could just display the current gear regardless of whether I'm in SportShift or not. That'd be a cool feature.
How would it be useful when you're in "D"?
Old Aug 3, 2003 | 07:36 PM
RJC RSX's Avatar
you can just pop it over for a second and see the gear and then pop it back
Old Aug 3, 2003 | 07:41 PM
jcg878's Avatar
Obnoxious Philadelphian
I find myself doing the same thing - just to spy on the transmission. I guess I just haven't adjusted to driving an auto. I'd like it to display the current gear all the time as well, but I agree that it wouldn't really be useful, just eye candy.
Old Aug 3, 2003 | 08:11 PM
Crazytree's Avatar
ditto.
Old Aug 3, 2003 | 09:30 PM
blahsome's Avatar
It would be useful because I'm interested in seeing how the auto tranny shifts. I'm a curious person.
Old Aug 3, 2003 | 09:38 PM
larchmont's Avatar
More On
Yeah. I thought you would have just been able to tell. But I guess not. (It's not like I'm sure I can, but I kind of thought I could, "give or take." I guess you want to do better than that.)
Old Aug 3, 2003 | 10:47 PM
jcg878's Avatar
Since 4th gear is geared so high in the AT, I feel like it's in 5th sometimes when it could be in 4th. That's what I'm usually checking - the other gears are more obvious. I read somewhere that both 4th and 5th gears are overdrives in the 5AT and they are responsible for the improved fuel econ of the AT vs MT (which my heavy foot is not realizing).
Old Aug 4, 2003 | 01:03 AM
XPLORx4's Avatar
My other "car" is a 4x4
I've found that when the transmission is set in "5" and the speed is around 45-50mph, it's pretty easy for the torque converter to unlock. It almost feels like the transmission is shifting into 4th, but it's not.
Is there any way to force the TC to stay locked in any gear?
Old Aug 4, 2003 | 02:39 AM
larchmont's Avatar
More On
So THAT'S what's going on!!
Obviously I don't have the answer, but thanks!
Old Aug 4, 2003 | 08:08 AM
combustible1's Avatar
I don't have a triptronic-type car, but wouldn't you just tap the lever over to the triptronic side, and it will maintain that gear for you?
Old Aug 4, 2003 | 08:21 AM
rzee's Avatar
Yes, it will maintain the gear, unless your rev is too low to keep the engine running.
Old Aug 4, 2003 | 08:27 AM
yep, that's what I thought.. there's your answer, XPLORx4.
Old Aug 4, 2003 | 08:55 AM
rzee's Avatar
No man, he was talking about torque convertor lockup, not whether the computer will hold your gear.
Old Aug 4, 2003 | 09:48 AM
donutchow's Avatar
how can you not tell what gear you're in by rpms? or when you start driving from a stop, you're in first, then it shifts, then it's in second. not hard at all. it's common sense
Old Aug 4, 2003 | 10:58 AM
larchmont's Avatar
More On
Right.
I didn't think they were answering the Q either -- glad to know I'm actually learning something!
Old Aug 4, 2003 | 02:11 PM
XPLORx4's Avatar
Too bad the TC doesn't have a "lockup" feature. In my SUV, turning off overdrive (4th gear) forces the TC to lock in 3rd gear at speeds above 50mph, even if the engine lacks the power to maintain a constant RPM.
Maybe using "D3" locks the TC? Of course, in D3, it will be hard to find an engine-load situation (i.e. very steep grade) in which the transmission will need to unlock the TC to get more power.
pstomps
Feb 20, 2017 03:29 AM
HOWELLiNC
3G TL Photograph Gallery
24
Oct 8, 2015 03:15 PM
datadr
Sep 12, 2015 09:12 PM
phillyguerrilla
Sep 11, 2015 06:39 PM
tealt
Sep 1, 2015 09:03 AM
