spark plug
Old May 7, 2008 | 05:09 PM
GrayTSX05's Avatar
spark plug
hi
when we should change the spark plug for tsx? I am wondering since a lot of peole change it here, and how do you tell when it needs to be changed
Old May 7, 2008 | 05:22 PM
godfather2's Avatar
Time to Climb
we have awesome ngk iridium spark plugs right from the factory. really no need to change until 100k miles
Old May 7, 2008 | 07:43 PM
Jim Holloman's Avatar
As godfather2 said, 100 K miles. The first tune-up is officially at 110 K miles. I would opt for 100 K, and hope that the factory used anti-seize compound on the threads -- otherwise, it might be like removing oxygen sensors. Only the tip is iridium.
I believe iridium is the most anti-corrosive metal known to man.
Old May 7, 2008 | 10:26 PM
peterjedi's Avatar
The TSX OEM plugs have been either Denso (.7mm) or NGK (.7mm).
After market plugs for Denso are .4mm. You can't by the OEM Denso plugs at .7mm. At least I couldn't find them. The NGK aftermarket plugs are OEM .7mm.
Some say you are suppose to get better MPG with the smaller electrode of .4mm, but I havn't found a source to confirm this. The NGK .7mm plugs will last you 100k before replacement, while the Denso .4mm plugs will last you 60k.
These Iridium plugs are probably the best plugs for a TSX that's used as a daily driver.
The other major difference between the two plugs is the U-grove (Denso) vs flat nose (NGK).
Old May 7, 2008 | 11:18 PM
lcrazyaznl's Avatar
CL9 ABP
Any ideas what a bad iriduim spark plug looks like?
I had to replace my first set around 30k since i had a bad 02 sensor and crudded up my sparkplugs.
Mike734
Dec 10, 2021 01:25 PM
acuratl26
Apr 23, 2020 07:30 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
