Seat Presets Won't Move With Remote
Hey guys,
I recently noticed that my driver's side seat will not move with the remote to the preset positions (based on remote) when I open the door.
The positions are still there as the seat does move when I press either number 1 or number 2 to its set position.
What is wrong with the car? Did I turn off something accidentally?
Thank you in advance for any advice/tips.
I thought in the MID display settings, there was one option to have the remote link to the seat. Not sure if DLTSX6MT's suggestion will essentially enable this, but if not, you might want to check that (assuming you have 2006+, not sure if this is available prior to that).
Hey guys,
Thanks for the responses. I have an 08 and I did read the manual saying something about the MID by holding down the info button. I was planning on resetting everything (holding "i" and press reset) but the display said it did not recognize the key and will not let me reset.
I'm about to do what DLTSX6MT said right now. I'll let you know how it goes.
Thanks again.
Thanks again.
if you still can't get it to work, try the link below:
https://acurazine.com/forums/1g-tsx-problems-fixes-128/unidentified-driver-728141/
i couldn't get it with the manual info and I did what's in the post above and it worked.
rockyboy
Aug 4, 2024 10:35 AM
Sep 17, 2015 09:01 PM
