S2000 vs. TSX tranny.
Similar? Different? Identical???? (someone told me this)
Reason I ask is because the only manual tranny I have driven on has been an S2000.
How does it compare, (clutch, throws, etc.) with the TSX 6MT?
Nothing at all is the same. The TSX is mounted to a transverse engine and the S2000 is longitudinal. Throws are shorter in teh S2000, the clutch has less play in the pedal (easier to use, though lighter and takes an adjustment to get used to) in the TSX...this coming from a previous owner of an S2000.
Much softer clutch on the TSX, longer throws on the shifter too. I read somewhere we're talking 41mm vs. 31 mm. but I can't remember the source nor verify if this is really true. But it is definately longer throws.
Like I said. Longer throws in the TSX. Hey, Colin, I got your PM the other day and then couldn't reply to it...we all know why now. All is good over here. I even tried to call you at the store and then they told me you don't work Saturdays. You suck. I work 9-9 on Saturdays.
the tranny is connect to the engine on the side. Therefore, on a longitudinal engine, the shifter is usually directly connect to the tranny, whereas on a transverse engine, you have shift linkages.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Originally posted by PimpDaddyKABZ
ah.....I understand....
so I'm sure the TSX tranny would be simpler to operate because of that as well, am I wrong?
Here's how the S2000 tranny is:
![](http://world.honda.com/S2000/technology/image/bring4_01.gif)
and what about the TSX?
that disappoints me![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
I learned on an S2K, and it was fun as hell....
so how would compare that to driving a TSX.
Is this 6MT still fun? Easier to handle? Harder to handle?
baaah
that disappoints me
baaah
baaah
that disappoints me
baaah
Cheers,
Jaeger
baaah
that disappoints me
baaah
I'd rate the TSX manual third (in cars I've driven) behind the S2k and Miata.
Edit: Have you test driven a TSX yet? If not, do it!
As an owner of an S2000, I have to say that nothing compares (completely unbiased opinion here
). I guess the fact that they both have 6 gears is reason enough to compare but they are 2 different cars. Anyway, on my test drive with the TSX, I had a heck of a time going from 5th to 6th.... keep wanting to go into 4th. Anyway, like everybody else said, longer throws, softer pedal feel, etc...
On a side note... my model year (2000) of my S2000 did have a problem with the clutch pressure plate. When you let up on the gas, there was this noise that sounded like an exhaust noise but turned out to be the pressure plate flexing (light weight version). I never noticed the noise but my dad who happens to be a service manager for Honda noticed the noise and had the 2003 version (clutch and pressure plate) swapped in (covered under warranty). The 2003 model year reinforced this area. Now I could hear the real exhaust note and it sounded so much sweeter.
mlody
12-04-2019 02:11 PM
GWEEDOspeedo
01-15-2016 10:39 PM
