replacing bulbs
replacing bulbs
alright, i have decided to replace all of the interior bulbs on my tsx, as well as the license plate and trunk bulbs.
for the doors i am using: T13-B6 Blue LED bulb
for the domes i am using: 3022-4 LED Festoon bulb
and for the trunk: T13-B6 Blue LED bulb
and the license plate: WLED-B4 Blue LED bulb
now, all of these bulbs should work properly right?
one thing i am unsure of though, is what size bulbs do i need for the vanity lights under the mirrors? it is a fuse type bulb.
also, on the canadian model is there a glove box light or not? i couldnt seem to see one.
i am getting all of the led's from superbrightleds.com
Re: replacing bulbs
However, if you intend to do the reverse lights, I've found that the 7443 White LED can be converted to a 7440 bulb just by twisting the secondary wire around to the primary wire.
If you haven't found a place to buy the LEDs, I suggest
http://www.superbrightleds.com. I used them.
