Remote Starter
Canuck
Originally Posted by aznt1217
search pwns u.... Acura uses DEI's remote start system.
Most likely the dealer sends the car out to a local audio shop to get it installed.
I do believe remote starter is an option on the CSX though.
Received 3,842 Likes
Originally Posted by narci
Reference?
Im not really worried about the cost cause it was part of the deal for buynig the car. So they threw it in for an extra $100 including installation. I was just curious abuot how good the quality of the starter is.
Why not just ask the dealership from which you bought it at?
Canuck
Just to clarify the remote starter, for the TSX there's usually 3 modules.
the actual remote starter/alarm brain
a bypass module to handle it immobilizer
another bypass module to handle the security chip in the key
example:
My remote starter is made my Autostart
I use a Honda SL module for the security key and a bypass module (from bypasskit) for the immobilizer (or was it the other way around)
So in essense I have 3 different components from 3 different companies.
You might want to ask about the different components in your starter and who makes them.
And about Acura having a OEM remote starter, I asked my dealership before and they said they don't do it. I went visiting after I got mine done, demo'd it to the sale person and they wanted to know where I got it done because it was a flawless intergration witht he OEM alarm/locs/etc... and said they might use the same company to do other requests.
example:
Well Paragon Acura in NY, uses DEI Valet autostart systems. That's my "reference" Acura doesn't make OEM starters, what they did for me was they included the Autostart with LoJack as a package. Just ask them what they use.
example:
example:
however I bet that they are all made by DEI
Canuck
http://www.autostart.ca/HTML_Frame.htm
Bypasskits is Canadian as well Based out of Ottawa and looks liek they distribute thier own stuff:
http://www.bypasskit.com/aboutus.aspx
Honda-SL i'm not sure if they make thier own, they are based out of Quebec too:
http://bypasskits.fortinautoradio.co...bypasskitid=41
I think DEI does make thier own modules too as well as remote starters/alarms.
actually...i called the dealership like u guys said...and apparently the job was done by some outside company...and its the remote starter is made by audiovox...and...apparently its a model that has been discontinued or something
TSX4EVR
I have the nu-start remote starter which is a redressed compustar. It works very well and does not require the valet key.
I got it thru the dealer but I knew the shop that they used, visited the shop and talked to them before deciding to get it and I knew what the price was. I actually got lucky because I paid the price for a one way remote starter and got a two way starter.
The remote starters are great, but one word of caution is that you lose some of your key fob functionality.
Excited
Excited
These are the features of the starter:
* Remote start your vehicle using your original equipment transmitter or your alarm transmitter
* System will not compromise the primary function of your transmitter, whether it be security, keyless entry or both
* Remote Start Safety Control Switch
* Selectable Automatic Timed Start Mode (2 Or 4 Hours Selectable intervals)
* On-Board Start Relay
* On-Board Accessory Relay
* On-Board Ignition 1 Relay
* On-Board Ignition 2 Relay
* Ignition 2 Relay Selectable On or Off During Cranking
* On-Board Parking Light Relay
* Ignition 3 / Shock By-Pass / GM VAT Output (relay required)
* Tach Signal Learning Circuitry
* Two ( + ) and Two ( - ) Safety Shutdown Circuits
* Alarm By-Pass Outputs
* Selectable Steady or Flashing Parking Lights for Run Indication
* Selectable 10 or 15 Minute Run Time
* Factory Keyless Upgrade Inputs (Allows Starting From Factory Keyless Entry Unit)
* 4 Auxiliary Outputs To Allow Control Of A Factory Alarm
* Safety control switches
* Vehicle remains secure during remote start
* Can be used with gasoline or diesel engines
* Vehicle must be equipped with an automatic transmission and a fuel injected engine
Is it any good?
Is it any good?
Canuck
whats the difference between a 2 way starter and a 1 way
Ok.
One way is if you press the remote to start the car, you will not get a confirmation beep back to say the car has started.
Two way, you will get a confirmation beep back if the car is started. Two ways usually used in conjunction with those fabcy LCD remotes though I don't have a fancy LCD remote because thery break easily and it's $$$ to replace.
This is the model I have. I have been on the 11th floor of a condo and in an elevator and successfully started my car parked in the outside parking lot.
AS-2300 TW
PREMIUM CONVENIENCE SERIES
2-way automatic transmission remote starter.
FM system.
HDX technology.
Up to 2500 feet of range.
5 button 2-way transmitter.
Easy to use shift key operation.
Visual command confirmation via buttons illumination.
Audible confirmation via Piezo speaker.
System status request mode with engine runtime.
Keyless entry, engine disable, trunk release, horn panic.
Antenna with embedded ultra bright Blue LED.
Two configurable auxilary outputs.
Turbo timer mode.
Communication port for optional 5 channel and dome light supervision expansion module.
TSX4EVR
They gave me two remote fobs. One a fancy LCD fob and the other just your ordinary looking fob. I just use the ordinary looking fob. I have trouble reading the LCD fob without my reading glasses (which is why I had just ordered the one way)
Excited
Excited
If you have the Acura dealer install the remote starter (at the time of purchase), then would it be covered under the same new car warranty (4yrs/50k miles)? If so, that would be a big advantage over an aftermarket one.
Would a dealer installed one still possibly have some loss of functionality? I know I had an aftermarker one in my 02 Toyota Solara, and it somehow couldn't interface properly to have the remote trunk opener work anymore.
Lastly, would different dealerships install different model remote starters? That might be a factor in deciding which dealership I end up getting it from.
Thanks.
Jeff
Thanks.
Jeff
TSX4EVR
Thanks.
Jeff
Thanks.
Jeff
Mine is a high quality starter install by a top notch company but it cancels out some of the features of the original key fob. The OEM fob does all the standard things like open and close the doors and opens the trunk but it does not allow for all of the mid changes unless you synch it up to the car again.
I would imagine that different dealers would use different starters. I think whatever the main starter is that their partner uses is the starter that they would go with.
Excited
Originally Posted by Jeff The Pianist
quick question...what's a LoJack?
A vehicle recovery signal. It's a transponder that is mounted somewhere in your car. When you report your car stolen to LoJack, they send out a signal to your car to basically start broadcasting. I think affliliated police departments have a locator device which they are able to use to track down your car (based on distance and direction).
Jeff
Jeff
Jeff
Let me help you!
Originally Posted by qweezyq
Does installing a starter affect the manufacturers (Acura) or extended warranty?
If you were to have another problem...like a suspension problem, then they can't blame it on the remote starter.
But in either case, the dealer still has to prove it.
[QUOTE=...But in either case, the dealer still has to prove it.[/QUOTE]
Since it's the dealer who's potentially spending their money (for the repair), they might take the attitude that unless they can be totally sure the remote starter isn't the source of the problem, they'll decide not to cover the repair.
A remote starter is in a sense particularly nasty, it connects to the electrical system, starting system, lights, brake lights/pedal, etc, that there is just so much opportunity to have problems with a bad installation or faulty unit.
Jeff
Jeff
Originally Posted by cibs
excited - what other features do you lose from the OEM fob that you noticed, when installing an aftermarket remote start or alarm?
- unlock both doors before you start the car, then start the car
- start the car with the doors locked. When you get to the car, remote stop the car, then unlock the doors.
- don't initially access from passenger side, open car from driver's side, where you can use the key.
This remote-disable behavior was the same on my last car (02 Solara), so it could be common. At least on that car, the remote start I had installed had it's own controls for door lock/unlock and trunk unlock, which were separate from the factory remote, and thus still operated. Unfortunately the remote starter I had installed on my TSX is remote start only, no separate unlock capabilities.
Jeff
I would definitely look into a combo unit. The only reason I didn't do that is I got my remote starter installed by the dealer at purchase time, so supposedly any issues with it are covered by the 4yr/50k warranty. The unit they support (and installed) is a starter-only one.
When I had the remote combo unit with my Solara, there was an issue where the remote trunk function didn't work. Supposedly there was a separate module that was needed to work it which wasn't available when I got my remote installed. I never bothered looking into it later, being able to still lock/unlock the doors was good enough. One bonus of a combo unit with this is that it likely will also provide automatic locking/unlocking of the doors either when you go into/out of park. (At least some people would like that capability).
Jeff
Jeff
SinCityTLX
10-07-2015 01:24 PM
