Random warning chime and display blink
Old 01-01-2019, 08:32 PM
kst123's Avatar
Hi! Have recently been noting something that I had not experienced before. While driving the car, I will hear the warning chime followed by a quick blink of the display system. No warning lights come on and everything goes back to normal. Has happened 3 or 4 times now on a long road trip I recently took. Basically, highway driving for a few hours and I will hear the chime/beep and a quick blink of the display and everything back to normal. I had a new battery and a new ignition coil put in a week before the trip. Any ideas as to what might be triggering this?
A couple of other things that seem to be happening after getting the above repairs is a noise coming from the AC/heat when turned on and a general burning smell from under the hood. Wondering if all these are somehow connected? It is an 07 TSX with 175K miles on it.
Thanks!
Old 01-02-2019, 06:52 AM
acmectec2001's Avatar
I had a similar issue. The car had been fine. Drove it on the interstate for a while, got off the exit and everything started blinking. The negative battery cable was slightly loose I'd start checking connections.
Old 09-16-2022, 01:36 PM
tyeh101's Avatar
I got similar issue for 2008 TSX. The chime sounds like the door open with key and the display blinks once whenever I heard the chime. The sound came out from time to time but not in high frequency. Any one figure out the possible cause? Thanks!
Old 09-18-2022, 12:56 PM
altair47's Avatar
New ignition coil? Who is the manufacturer of these coil?
Old 09-18-2022, 01:24 PM
tyeh101's Avatar
Oh, my 2008 TSX still has the original ignition coil. The problem lasts a while long before the power steering rack was replaced recently by Honda dealer. Because it only happens from time to time and we don't drive this car a lot (around 42K for 14 years). Therefore, I forgot to follow up this issue with Honda when the power steering rack was replaced.
datboimarn3
1G TSX Problems & Fixes
03-31-2012 08:51 PM
Aretardedorange
12-15-2011 05:50 AM
TL-TYPE S
04-18-2011 11:00 AM
fliplyricist1
11-25-2007 06:48 PM
SouthernBoy
10-31-2004 09:40 PM
Quick Reply: Random warning chime and display blink
