Quaker State 4X4 Synthetic Blend--Best Bang for your buck?
Old Jul 19, 2005 | 02:35 PM
SodaLuvr's Avatar
QS 4X4 Blend, Is this the best bang for your buck blend?
Analysis by Knapp Chevrolet in Houston.
Quaker State 4X4 Synthetic Blend, 5w-30
API SM, ILSAC GF-4
Fe, 1ppm
Pb, 2ppm
Sn, 1ppm
Si, 1ppm
K, 1ppm
B, 230ppm
Mo, 402ppm
Ca, 2520ppm
Mg, 18ppm
P, 776ppm
Sb, 226ppm
Zn, 884ppm
All other elements were reported as zero.
Viscosity @ 100C, 10.8cst
TBN, 9.0 (Dexil)
Looks like a very robust oil for $11/5-quart jug at Walmart. Nice to see them use Antimony and a good dose of Molybdenum in such a low end oil. I expect the 5w-20 version to be just as robust, if not even more. Seems like I've found the next elixir for the TL, and the best bang for your buck, most robust synthetic blend oil for around $2/quart.
Michael
Old Jul 19, 2005 | 02:36 PM
SodaLuvr's Avatar
Explanation:
Mo, Friction Modifier
P, Anti-Wear
Zn, Anti-Wear
Mg, Detergent
Ca, Detergent and increases TBN.
Sb, AW
Hope this helps,
Michael
Old Jul 19, 2005 | 03:39 PM
STL's Avatar
STL
How do those numbers compare to Mobil 1 Synthetic?
Old Jul 19, 2005 | 07:44 PM
SodaLuvr's Avatar
STL,
Additive pack is more robust. However, it doesn't compare to M1 in the same class as M1 is a GrpIV syn where as this is PROBABLY a Grp II+/GrpIII product. In addition, M1's TBN will start out at about 9.5 on the D-4739, whereas this one starts out around 7-7.5 on the D-4739 and 9.0 on the Dexil. Thus, M1 MAY have a longer service life.
However, this oil is VERY hard to beat for its price to performance ratio.
Michael
Old Jul 19, 2005 | 08:30 PM
curls's Avatar
Someone stole "My Garage"
Originally Posted by Michael Wan
STL,
My cat's breath smells like cat food!!
(please dumb it down to gas-n-go peoples' level!)
Old Jul 19, 2005 | 08:50 PM
Savio's Avatar
TSX
should I break out my periodic table?
Old Jul 19, 2005 | 09:04 PM
SodaLuvr's Avatar
TBN= Total Base Number, amount of active additive in the oil.
D-4739, D-2896, and Dexil are all methods of measuring the TBN.
Savio, try webelements.com.
Michael
Old Jul 19, 2005 | 10:52 PM
J0E's Avatar
J0E
yeah umm so if money wasn't a problem for an oil change that would be done every couple of months what is the best to get easily or at the dealers
Old Jul 20, 2005 | 09:37 AM
SodaLuvr's Avatar
J0E,
For short, 4-6 mo OCIs, I usually suggest a good dino or blend. The Quaker State 4X4 Blend would be a good oil to use in this case, for 4-6 mo or 3000-5000 mi. OCIs. This service interval is ideal for a short tripper, or a car that puts in less than 10K a year, where an oil change with a quality dino or blend should be done every 6 months, as the car is probably used for many short trips.
Michael
jterp7
3G MDX (2014-2020)
Feb 3, 2016 08:34 PM
DerrickW
Nov 15, 2015 05:52 PM
lanechanger
Oct 13, 2015 10:56 AM
Jboat
Sep 30, 2015 10:58 AM
