Quaker State 4X4 Synthetic Blend--Best Bang for your buck?
QS 4X4 Blend, Is this the best bang for your buck blend?
Analysis by Knapp Chevrolet in Houston.
Quaker State 4X4 Synthetic Blend, 5w-30
API SM, ILSAC GF-4
Fe, 1ppm
Pb, 2ppm
Sn, 1ppm
Si, 1ppm
K, 1ppm
B, 230ppm
Mo, 402ppm
Ca, 2520ppm
Mg, 18ppm
P, 776ppm
Sb, 226ppm
Zn, 884ppm
All other elements were reported as zero.
Viscosity @ 100C, 10.8cst
TBN, 9.0 (Dexil)
Looks like a very robust oil for $11/5-quart jug at Walmart. Nice to see them use Antimony and a good dose of Molybdenum in such a low end oil. I expect the 5w-20 version to be just as robust, if not even more. Seems like I've found the next elixir for the TL, and the best bang for your buck, most robust synthetic blend oil for around $2/quart.
Michael
API SM, ILSAC GF-4
Fe, 1ppm
Pb, 2ppm
Sn, 1ppm
Si, 1ppm
K, 1ppm
B, 230ppm
Mo, 402ppm
Ca, 2520ppm
Mg, 18ppm
P, 776ppm
Sb, 226ppm
Zn, 884ppm
TBN, 9.0 (Dexil)
Michael
STL,
Additive pack is more robust. However, it doesn't compare to M1 in the same class as M1 is a GrpIV syn where as this is PROBABLY a Grp II+/GrpIII product. In addition, M1's TBN will start out at about 9.5 on the D-4739, whereas this one starts out around 7-7.5 on the D-4739 and 9.0 on the Dexil. Thus, M1 MAY have a longer service life.
However, this oil is VERY hard to beat for its price to performance ratio.
Michael
Michael
Someone stole "My Garage"
Originally Posted by Michael Wan
STL,
(please dumb it down to gas-n-go peoples' level!)
TBN= Total Base Number, amount of active additive in the oil.
D-4739, D-2896, and Dexil are all methods of measuring the TBN.
Savio, try webelements.com.
Michael
Michael
J0E,
For short, 4-6 mo OCIs, I usually suggest a good dino or blend. The Quaker State 4X4 Blend would be a good oil to use in this case, for 4-6 mo or 3000-5000 mi. OCIs. This service interval is ideal for a short tripper, or a car that puts in less than 10K a year, where an oil change with a quality dino or blend should be done every 6 months, as the car is probably used for many short trips.
Michael
Michael
jterp7
3G MDX (2014-2020)
02-03-2016 08:34 PM
DerrickW
11-15-2015 05:52 PM
lanechanger
10-13-2015 10:56 AM
