Password JDM fogs
Password JDM fogs
Hey guys, I recently purchased an '04 PWP Tsx and the OEM fogs are pretty much all cracked.
I just ordered some yellow passwordJDM fogs to replace them. I was wondering if I"m going to have a difficult time replacing them or will it be plug and play with the OEM wiring? Are the harnesses the same? I don't plan to wire and install the switch, I want to use the OEM wiring.
Lastly, do you think it makes a difference if I use yellow or clear Lamin-X to protect them? Since the fog lense is yellow already.
thanks!
thanks!
I ordered these:
http://passwordjdm.com/PasswordJDM-C...w-P1508C0.aspx
Hopefully the housing is the same as OEM so I just have to plug the harness into it.
Or maybe someone has had experience replacing OEM fogs to these
I have never seen how the OEM ones are wired into the back of the housing, but I assume its just a plug that connects right into the H11 bulb, so you wouldnt need to change any of the wiring. I wouldnt think youd need to anyways. The housing is the same, it fits perfect.
Again, I doubt it very much that you need the jdm wiring harness.
Jul 16, 2017 07:33 AM
