Octane
Like It Smooth!
Octane
In the midwest we have premium 93, plus 89 and regular 87.
Does anyone know if these different grades of gas was prep at the refinery or addictives later added at the gas station?
Maybe I'm retarded for asking this but I usually noticed the truck only replenishs the reservoir with one outlet. Now does the truck come loaded with a different grade each time or could there be 3 different compartments in the tank?
Re: Octane
Refineries make two grades, premium and low end. The others are blends of the two.
Shell and Mobil may come from the same refinery where oil is refined to government specs but as the truck leaves their special formulas are added.
Basically, run the lowest octane your car was built for. Running lower than that can cause engine damage. I think TSX is 91 but some places go from 89 to 93.
There is an argument that you should not use the same brand of gasoline for an extended period of time. Those who subscribe to this usually say use one brand for 5,000 miles then switch to another major brand for 5,000 etc. because deposits caused by the different brand additives build up.
Like It Smooth!
What was stated above does not make sense.
Why would you want deposits to build up otherwise?
I have been using Shell 93 in all my vehicles for over 10 years with no problems.
And I do apply fuel injector cleaner every 3 months and fuel system cleaner every year.
Moderator Alumnus
Re: Octane
Originally posted by ecsw
No, I am pretty sure Gas are the same, but it's just the addictives added to it while u pump.
Are you saying one should stick with the same brand or no?
There also is a theory that if you use low octane to put a tank full of high octane in there every fifth fill up or so.
d.brandusa
06-22-2005 11:53 PM
