Not sure if slave cylinder or...
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Hello A'zine! Always a pleasure to bring a problem before you guys lol. Anyhow, here is the situation. My clutch pedal won't come back up :/. Being that as it my, I obviously can't put my car into gear to drive her
. However, the thing is if I pull it back up by hand and press it insanely fast/pump it I can BARELY manage to get it into gear, but the amount of quick force in addition to the amount of times necessary to get ANY resistance/spring back in the clutch pedal is way beyond practical for regular driving. I've been hearing and reading clutch slave cylinder but I don't recall anyone commenting on whether or not quick successive pumps were able to get them a reaction or not. So I come to you guys in hope of a definite answer ![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
EDIT: I just realized this is in general discussion can a mod please move this to problem and fixes (if thread location is a problem).
So I got my car back and they did clutch slave and master cylinder and I have two problems making me very uneasy. One is that when I'm shifting it's either hard or notchy. I've grinded second gear twice today in the few hours I've had it and a notchy/rough entry into fourth and sixth. The other problem I have is that now my brake pedal is so soft! I tried to convince myself it was all in my head but I heel toe quiet a bit, and the point at where my brakes bite is a good bit lower and as well so soft!
https://acurazine.com/forums/1g-tsx-problems-fixes-128/solved-clutch-pedal-low-engagement-point-837892/#post14751248
Is shifting into gears notchier on cold starts? And it seems to get better as the engine warms up? If so your mechanic probably didn't adjust your clutch pedal correctly. Same issue happened to me when I changed out my CMC.
https://acurazine.com/forums/showthread.php?p=14751248
EDIT: I clicked on your link and found out it was the same one I used to adjust my clutch in the first place lol.
As for your brakes, I'm not really sure. Ask your mechanic about it? Spongy feeling the in the brakes usually means air in the system. But if your mechanic never touched the brake system then I'm not sure how to help. Check brake fluid reservoir?
**UPDATE** So I've been driving my car for a while to see if things would settle and lo and behold, they didn't. If anything now it's worse. For starters, I cant shift out of first gear unless my foot is some what on or barely leaving throttle. Otherwise, it'll hold my shift lever and vehemently refuse to let go until some time has gone by (presumably as the revs die down). As well, occasionally shifting into first gear is a huge hassle unlike the ease it was before. I admit that I was and still am a little hesitant to bring my car back to the mechanic as the first time he felt nothing was wrong with the car even though I (who drives it everyday) insisted something was off. But at this point it's gotten too bad to ignore. Anyone want to chime in?
SidhuSaaB
05-30-2020 12:40 AM
mlody
12-04-2019 02:11 PM
joflewbyu2
10-08-2015 11:16 AM
