Need Replacement Wheel Lock Key
Old 01-21-2018, 10:37 PM
6th Gear
gbwiii's Avatar
Purchased a used 2008 Acura TSX and just realized there's no wheel lock key in the trunk ! How do I get a replacement key ?
Old 01-22-2018, 07:11 AM
mrgold35
mrgold35's Avatar
Received 1,519 Likes on 1,185 Posts
Is the standard OEM wheel lock sold by Acura? You can go to any Honda or Acura dealership for removal or replacement. Pretty much 99% of tire shops will have a key for the OEM wheel lock if you just want to remove and replace with a regular lug nut. The only issue you might have if you want to replace the OEM wheel lock with aftermarket lock is OEM wheel lock are made for OEM wheels with ball (rounded) lugs and most aftermarket wheel locks are usually tapered/cone (straight sided) design. Cannot mix ball and tapered/cone lug nuts if the OEM rims require ball lugs.
justnspace (01-22-2018)
Old 01-22-2018, 08:58 AM
6th Gear
gbwiii's Avatar
Thank you for the info greatly appreciated !
DuoDSG
02-26-2013 09:53 AM
6spdtl-s
07-01-2009 09:11 AM
HyDrOpOnIkToKa
06-27-2006 04:29 PM
StonedCL
11-15-2005 07:46 AM
mrsteve
2G CL Transmission Recall Q & A
01-24-2005 02:22 PM
Quick Reply: Need Replacement Wheel Lock Key
