Need the help of a few members
Old 09-10-2008, 02:58 PM
csmeance's Avatar
Received 2,016 Likes on 1,435 Posts
Hi guys,
I need your help. For those of you who have access to a micrometer or a caliper, can you measure the thickness of your key in the front (3 millimeters from tip), the thickness of the "blade" the thinner portion that has the cuts in it, and also the width of the key at the front.
I need it in inches to the .001 -.0001 measurements. My dealership isn't letting me try the key in the glovebox or the rear-shelf, but did agree to see if it slid into the door, which it did.
I appreciate the help guys
aj
Old 09-10-2008, 06:04 PM
Oliver!!!
litesout's Avatar
Guys, if anybody out there can provide measurements, please do. I'm going to try and pick up a caliper tomorrow if I get a few extra minutes.
Old 09-10-2008, 06:50 PM
Team Hybrid
l7h8626's Avatar
shouldnt it be the same as the TL keys? I dont remember FLBUSA makes diff keys for TL and TSX.
Old 09-10-2008, 07:03 PM
Former Sponsor
MrHeeltoe's Avatar
Originally Posted by csmeance
Hi guys,
aj
If the key works in the ignition and the door, but no other locks in the car, it is a VALET key. It is thicker, and probably a grey color.
Marcus
Old 09-11-2008, 12:32 AM
DLTSX6MT's Avatar
Hi guys,
aj
Measured one of my original, virtually unused, keys w/ caliper (sorry, no micrometer handy):
0.0985" total thickness
0.0410" thickness of the side blades
0.312" width across two knubs
Old 09-11-2008, 12:37 AM
DLTSX6MT's Avatar
Some of the above comments aren't quite true. FLBusa initially made keys that worked perfectly fine in TL's, but not in TSX'x, especially the glovebox, trunk/fuel lockout, and rear seat releases. It wasn't related to valet keys. I don't even remember if it was the thickness (at least not directly). The real problem turned out being the sharpness of the milled edges.
Old 09-11-2008, 08:36 AM
CCColtsicehockey's Avatar
Received 3,860 Likes on 2,580 Posts
I would love to get this project up and running again hope you have success.
Old 09-11-2008, 11:10 AM
JDM Addict
MMsTSX's Avatar
that was obviously fixed along the way though.
I have a flbUSA key that works flawlessly in all locks, every single one
of them.
Old 09-11-2008, 11:15 PM
Oliver!!!
litesout's Avatar
Okay, my measurements varied very slightly from DLTSX6MT's. Unfortunately, all I could find was a cheap digital Caliper. The pictures are for reference only, don't use the measurements on the display, but the ones that appear just below the picture.
Okay, the key blade thickness is .100 (as shown in the picture.)
The thickness of the milled down part is .042
The width to the edge of the channel is .091
The thickness of the blade at the bottom of the channel is .060
And the width of the channel is .050
Again, the pictures are just for reference. And the caliper I used isn't the greatest, but I don't have access to a micrometer right now. And by the way, the measurements referenced below the pictures are from my spare key, which I don't believe has ever been used. And if it has, it's not been used more than once or twice. Hope this helps.
Old 09-13-2008, 10:36 PM
DLTSX6MT's Avatar
of them.
ditto
vpasla1
09-17-2016 07:24 PM
navtool.com
Sponsored Sales & Group Buys
87
01-23-2016 01:25 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
lanechanger
10-13-2015 10:56 AM
Quick Reply: Need the help of a few members
