my new modded TSX KEY
Old Aug 19, 2005 | 08:24 AM
  #121
rbf351's Avatar
Registered User
Originally Posted by moda_way
Please post your results. I still have my Accord chip, but I won't have time to mess with it until next week.
just looked at the part numbers.
The TL and 4 door EX, EX-N, and LX-N Accord share the same exact Immobilization unit which is part number 39730-SDA-A01
The TSX and 4 door Accord LX and DX share the same exact Immobilization unit which is part number 39730-SDA-A11
didn't check the 2 door parts numbers, but i'm sure they are the same too
that means they are identical units. the weirdest thing is that all of these cars (TL, TSX and Accord) share the same steering/key switch which is part number 35130-SAA-J51. this is where the key goes into(key cylinder)
you can search for the part numbers here to confim what i am posting
http://www.hondaautomotiveparts.com/...artsSearch.jsp
http://www.acuraautomotiveparts.org/...searchpart.jsp
Old Aug 19, 2005 | 08:34 AM
  #122
moda_way's Avatar
that is wild... because the keys are totally different between the Accord and the TSX... and I mean before and after they are cut. I don't have a micrometer, but by site, you can see the Accord key isn't as wide as the TSX key, but it is thicker.
You are a wealth of knowledge!! Great research.
Old Aug 19, 2005 | 08:37 AM
  #123
mg7726's Avatar
She said: it's GINORMOUS!
moda - i'm wondering if you got the locksmith to cut a copy of the TSX key into your blank accord, it 'might' fit and turn???
(sorry you're the gineua pig - take one for the team??)
Old Aug 19, 2005 | 08:42 AM
  #124
moda_way's Avatar
I used to work at a locksmith many years ago and the Accord key would need a channel cut down it on both sides and the a second area channeled out for the profile of the key, then the key set cut into it. If you take a look at my pics, you see that the Accord key is like a chunk of metal and you would have to completely cut out all the details of the Acura key in it. More than likely it would cost more than it is worth.
Is the point to avoid doing this mod and just have the Accord key in total modified?
I have put special attention to stressing my modded key out and after 2 days no signs of any stress on the epoxy'd area.
Old Aug 19, 2005 | 08:51 AM
  #125
mg7726's Avatar
i totally believe and have faith in your mod.
that said, i was throwing out suggestions on further hacking the accord key. sorry, i have no idea work involved in slimming down the key, or locksmith workings.
<-- goes back to my 2nd coffee now
Old Aug 19, 2005 | 09:03 AM
  #126
moda_way's Avatar
I wasn't question... just explaining.
BTW, I found a pic of the key on the JDM Accord brochure.
It is exactly like the USDM Accord key sans the panic button.
Old Aug 19, 2005 | 09:11 AM
  #127
rbf351's Avatar
Registered User
makes no sense, the keys are completly different. i have a feeling the steering switch is nothing more than a hole with a button that locks/unlocks the steering when the key is inserted and removed. it's not the actual key cylinder. thats a completly different part
Old Aug 19, 2005 | 09:26 AM
  #128
moda_way's Avatar
Very interesting. It sounds like it since the keys are radically different. I think your assumption is correct sort of having a cylinder to pull apart.
Old Aug 19, 2005 | 09:35 AM
  #129
rbf351's Avatar
Registered User
if my fiance doesn't want to go out tonight, then i will pull the TL apart and see how that part works, i would do the TSC too, but i don't think my brother would enjoy that. me installing Bluetooth was enough in that car
Old Aug 21, 2005 | 09:51 AM
  #130
JTso's Avatar
Originally Posted by JTso
Good information! Let me see if I'm understanding it correctly...
1. your new key - technically, I don't need a Acura key with the chip inside. I only need a copy of the original key so I can open door and turn the ignition switch. This is the key that will be cut up and inserted into the Accord keyfob.
2. Master key - This is one of the working original Acura keys.
3. Cut up the non-original key and inserted in the Accord keyfob.
4. Follow the programming instruciton with the Acura original master key and insert new key with the Acccord keyfob and chip for programming.
If I'm understanding this correctly, then all you need is the Accord keyfob, a copy of the key. No need to remove any transponder chip as you are programming the one in the Accord keyfob. Right?
Okay, the programming method didn't work but the copy key works great. Here are some pics. As you can see, the copy key allows an almost exact replacement including the reuse of the back cover screw. I simply removed enough plastic on top of the key and remove the old key from the cavity, then shaped the new key the same way and fit it back it. I just need to get the transponder chip programmed perhaps by a locksmith.
Old Aug 21, 2005 | 01:44 PM
  #131
Powered by Honda's Avatar
Would this mod work for a 2001 Accord coupe EX V6? I like that key!
Old Aug 21, 2005 | 06:06 PM
  #132
leftride's Avatar
i want to ride my bicycle
nice work JTso! i am going to try to get my transponder chip programmed this week, i have to call around and see who has a SDD programming tool.
Old Aug 21, 2005 | 06:09 PM
  #133
Wowowowowoow My Friend Is Gay!!!!!!!!!!!!!!!!
Old Aug 22, 2005 | 10:37 AM
  #134
joerockt's Avatar
Just dial 1911
Time to take your Ritalin...
Old Aug 22, 2005 | 10:39 AM
  #135
moda_way's Avatar
Yeah, I was like...
Old Aug 22, 2005 | 12:13 PM
  #136
Motohip's Avatar
I'm a llama :(
So, just to clarify...the remote functions WON'T work on a 99 CL?
Old Aug 22, 2005 | 12:23 PM
  #137
moda_way's Avatar
MrChad is going to make one for his 00 Accord, so if that works, then I would think it should work for the 99 CL.
Old Aug 22, 2005 | 01:36 PM
  #138
Motohip's Avatar
I'm a llama :(
Several posts back someone said it wouldn't work for the earlier generation TL and RL, but I don't know if it uses the same alarm as the CL. I'm tempted to buy one at the dealer and if it doesn't work I can just return it.
Old Aug 22, 2005 | 01:41 PM
  #139
moda_way's Avatar
It would be easy enough to test. Give it a shot. You might find out something we didn't know about. I don't remember that post though.
Old Aug 22, 2005 | 02:30 PM
  #140
oh yeah well that. I was about to type a message...and my buddy was lying on my bed and he stuck his ass out and said, "would you do me like this?"
It was so out of no where. I almost die from it and I just typed out my reaction since my fingers were on the keys. errrr ignore it.
Old Aug 22, 2005 | 02:55 PM
  #141
jlukja's Avatar
Well, what did you do?
Old Aug 22, 2005 | 03:15 PM
  #142
joerockt's Avatar
Just dial 1911
Awww, sounds like you two were meant for each other. :gheylaugh:
Old Aug 22, 2005 | 03:51 PM
  #143
dom's Avatar
dom
Old Aug 22, 2005 | 04:11 PM
  #144
ryobi1's Avatar
7th Gear
Would it be possible to use the transponder chip from the valet key?
Old Aug 22, 2005 | 04:23 PM
  #145
JTso's Avatar
Old Aug 22, 2005 | 08:27 PM
  #146
leftride's Avatar
well i am right where JTso is at.
I went and had a key cut at Lowes (hardware store) for about $2, but i have been calling locksmiths and they are wanting from $90 - $120 to program the car with the the new transponder chip. I am going to try calling again tomorrow.
The SDD programmer seems to be about $5000, but I think the process is rather simple for the locksmith. I will keep everyone posted.
Old Aug 22, 2005 | 08:36 PM
  #147
You cant program it yourself????
Old Aug 22, 2005 | 08:54 PM
  #148
leftride's Avatar
no i dont believe so, if you read my previous posts i found you need to use an SDD programming tool and JTso verified that the instructions that rbf351 gave didnt work.
from what I have read this SDD tool has replaced the on board programming of transponders.
Old Aug 22, 2005 | 09:35 PM
  #149
JTso's Avatar
That's just as expensive as going to the dealer. I'm sure it can be done cheaper.
Old Aug 22, 2005 | 10:46 PM
  #150
leftride's Avatar
i should hope so...i am starting (hoping ) to think that they were quoting me those prices for an after hour emergency price (i was calling after 6pm)
I think they just hook the SDD up to the car and add the new transponder.
Old Aug 23, 2005 | 05:21 PM
  #151
Motohip's Avatar
I'm a llama :(
I can't find that post anymore. I even searched for RL.
Well...as soon as I get paid, I'm gonna try this.
Old Aug 23, 2005 | 07:44 PM
  #152
moda_way's Avatar
I PM'd JTso to find out which bit he used to get the screw out. He said a #0, which might explain why I stripped mine out. I started off with a #00.
Old Aug 23, 2005 | 09:40 PM
  #153
9900rpm's Avatar
SDD tool is needed to program the chip in the keys (in this case, the Accord key/remote).
Best way to do this mod IS to cut up a master key, and use the metal part and the immobilizer chip from that, inside the Accord key fob.
You can also cut up the valet key for the immobilizer chip in it, and have a key cut from your master key, that way you are only destroying the valet key (for people that want to keep 2 original keys).
The programming instructions for the immobilizer chip listed on page 4 (I think) will work, but it only lets the car start something like TEN times, then it will stop working. Somebody go talk to a good Honda/Acura tech if you don't believe me. The only way to do this right is with the SDD tool from Honda.
I hacked up one of my master keys and used the Accord key fob, TSX key, TSX chip. Works perfect.
Old Aug 23, 2005 | 11:55 PM
  #154
AchcA's Avatar
finished this mod today. all i want to say is u guys are going to love it when u done it. totally worth the work even lol i don;t have the right tools to do it.
Old Aug 24, 2005 | 05:54 AM
  #155
moda_way's Avatar
Yeah, I stated this before, but EVERY DAY since I've done this mod I'm reminded how much I love it. It simply hasn't gotten old. I smile everytime I go to open the car.
Old Aug 26, 2005 | 09:43 AM
  #156
Newplay1's Avatar
08 MDX with Sports
Just bought one accord key fob, will heck it up when I get a chance...
Old Aug 26, 2005 | 12:32 PM
  #157
TSX559's Avatar
I just got a copy of my master key yesturday. fits perfectly. now im going to get the accord key. i just have one question. can i have the honda dealer program the key for me or do i have to take it to the acura dealer? if honda can do it for me then this will be free. i have a friend that works at honda and he can hook me up. I havent ask him yet because i wasnt sure if honda can do it. but im pretty sure that they can. thanks for any help.
Old Aug 26, 2005 | 12:49 PM
  #158
JTso's Avatar
Yes, the Honda dealer should be able to do it as they all use the same HDS tool (Honda Diagnostic System).
Additonal info on the HDS...
https://www.serviceexpress.honda.com.../HDS_Chart.pdf
Old Aug 26, 2005 | 04:19 PM
  #159
TSX559's Avatar
cool. thanks jtso. im going to ask him today. see what he can do for me.
Old Aug 26, 2005 | 05:02 PM
  #160
kaikai114's Avatar
Got Milk???
been waiting for this forever!!!!
