my new modded TSX KEY
Old Aug 9, 2005 | 11:47 PM
bngu1's Avatar
just modded my TSX key into a the Accord keyfob. What you think????
Old Aug 9, 2005 | 11:49 PM
TSX 3Pedal's Avatar
Use all 3 Pedals at once
Is it a Honda "H" on the back of the key fob?
I want a key with the integrated functions, but I want an Acura "A" on mine
Old Aug 9, 2005 | 11:50 PM
euroStyle's Avatar
wow.
I'd like one too.
Old Aug 9, 2005 | 11:52 PM
bngu1's Avatar
i took the "A" off the old key and glue it where the "H" is.
Old Aug 9, 2005 | 11:53 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Very nice...where did you get the key?
Did you just take it to the dealer to get it programmed?
Thanks!
Old Aug 10, 2005 | 12:01 AM
euroStyle's Avatar
how hard or easy is it?
did you just take a blank accord key and get it cut?
Old Aug 10, 2005 | 12:06 AM
bngu1's Avatar
you can order one online for about $36 + shipping but i didn't want to wait for it so i went to a local Honda dealer and bought the key without cutting and programming for $60. it wasn't too hard but it does take some time and patient. programming the keyfob can be done fairly easy.
Old Aug 10, 2005 | 12:13 AM
TSX 3Pedal's Avatar
Can you give us a How-to on reprogramming the key fob?
Old Aug 10, 2005 | 12:31 AM
bngu1's Avatar
Storing transmitter codes:
The codes of up to three transmitters can be read into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps. Make sure the doors and the hatch are closed.
1. Turn the ignition switch ON (II).
2. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the receiver under the audio unit.
3. Within 1 to 4 sec., turn the ignition switch OFF.
4. Within 1 to 4 sec., turn the ignition switch ON (II).
5. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the receiver under the audio unit.
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 1 to 4 sec., turn the ignition switch ON (II).
8. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the receiver under the audio unit.
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 1 to 4 sec., turn the ignition switch ON (II).
11. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the receiver under the audio unit.
12. YOU SHOULD NOW HAVE HEARD THE SOUND OF THE DOOR LOCK ACTUATORS! Within 1 to 4 sec., push the transmitter lock or unlock button again.
13. Within 10 sec., aim any remaining transmitters (up to two additional ones) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored. (OPTIONAL)
14. Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation of the transmitters.
Old Aug 10, 2005 | 12:40 AM
JTso's Avatar
So, did you cut apart the new keyfob and insert your original key section with the transponder chip? Do you have some close-up pics?
Old Aug 10, 2005 | 12:43 AM
bngu1's Avatar
this is where i got the idea from http://forums.clubrsx.com/showthread.php?t=297852
Old Aug 10, 2005 | 12:55 AM
xjdmb16a2six's Avatar
7thGenAccord
thats koo. makes me wonder why acura didnt use the same key like the accords.
Old Aug 10, 2005 | 01:03 AM
jeffreytchui's Avatar
Delta Sigma Pi
MY EURO R CONVERSION IS COMPLETE (kinda) ur awesome!
Old Aug 10, 2005 | 01:40 AM
Alin10123's Avatar
Wow! Cool. Now only if they could do it like the VW or the older mercedes keys that fold up. hehe.
Old Aug 10, 2005 | 02:20 AM
Benz_05_TSX's Avatar
SWEET!!.....dat's awesome for the Euro R guys..... (JDM conversions)...
I thought we are never able to do that since we have that chip in our keys, without it, our cars won't start......hahah~
I always wanted a remote control/key
Old Aug 10, 2005 | 02:28 AM
TSX 3Pedal's Avatar
Thanks bngu1
Old Aug 10, 2005 | 06:26 AM
sauceman's Avatar
Moderator Alumnus
Good stuff! I'll list this in the DIY thread.
Old Aug 10, 2005 | 07:58 AM
iamhomin's Avatar
04 remembrance
Very interesting, I always wondered, thought I didn't mine, why Acura didn't have FOB keys.
Old Aug 10, 2005 | 08:25 AM
moda_way's Avatar
I checked out that RSX forum. You really gotta cut the crap out of the key. Otherwise, GREAT MOD!!!
Old Aug 10, 2005 | 09:04 AM
madmanmax3000's Avatar
Professional Newbie
If I didn't want to go through the trouble of cutting up my TSX key, could I just get the Accord key cut?
Old Aug 10, 2005 | 09:06 AM
moda_way's Avatar
We talked about this before and the Accord key itself is totally different. In order to make this work, you will have to put an OEM Acura key in place of the Accord key.
Old Aug 10, 2005 | 09:08 AM
MTLer's Avatar
Can you just get the honda FOB from ebay, and then take that blank key and get it cut at acura? Or is splicing both keys neccessary?
Old Aug 10, 2005 | 09:22 AM
Professional Newbie
oh man, I only have one key I don't want to mess it up. Any suggestions?
Old Aug 10, 2005 | 09:24 AM
tcwatkins's Avatar
Bet someone could pick up some easy bucks by buying a couple dozen acura blanks and doing this then selling them.
Old Aug 10, 2005 | 09:29 AM
MTLer's Avatar
You can get the blanks off of ebay, though most are aftermarket, but still good, the only issue is getting them cut and having the transponder programmed i guess.
Old Aug 10, 2005 | 09:43 AM
Professional Newbie
Which ones are the proper blanks I'm looking on ebay and i'm not sure which one to get. I'm going to need 1 Accord Key and 1 TSX key, all I can find is the TSX fob and there are a ton of Accord keys
Old Aug 10, 2005 | 09:45 AM
artmcd88's Avatar
"You are just a puppet.."
Why only one key...did you buy it used?
Old Aug 10, 2005 | 09:56 AM
MTLer's Avatar
There's this seller on ebay called streetkeys he sells them in a pair, I believe its after market, they seem more professional than others and have locations all over the world to program the transponder. Goes for 69.99.
Old Aug 10, 2005 | 09:59 AM
kangjin's Avatar
yup.
do you know the part # of the accord key?
Old Aug 10, 2005 | 10:22 AM
moda_way's Avatar
I've looked everywhere for the Honda part number and I can't find anything. Looks like they don't promote that number on the Internet and it makes no sense to me.
Old Aug 10, 2005 | 10:33 AM
rbf351's Avatar
Registered User
you just need to know where to look
http://www.partspeis.com
part number is
35118-SDA-A11
Old Aug 10, 2005 | 10:35 AM
moda_way's Avatar
part number is
35118-SDA-A11
I'm only a simpleton I have the following:
http://www.slhondaparts.com/
http://www.hondaautomotiveparts.com/...artsSearch.jsp
Old Aug 10, 2005 | 10:39 AM
rbf351's Avatar
Registered User
most people do not know the site i posted. it's the database that the dealerships use. it was given to me about 5 years ago
Old Aug 10, 2005 | 10:46 AM
moda_way's Avatar
So, do we have a cheat for a login or do you "know someone"?
Old Aug 10, 2005 | 10:53 AM
rbf351's Avatar
Registered User
i don't know anyone, but i was given the username and password back in 2000, and honda hasn't changed it since then. since i can not give out the username and password, i will give a hint that they are both the same and have the word honda in it. Basically if you need a part number for anything and can't find it then PM me and i'll get it to you
Old Aug 10, 2005 | 11:43 AM
JTso's Avatar
It's interesting that the site said "Not Available For The Dealers".
Old Aug 10, 2005 | 12:18 PM
CJams's Avatar
Guinea Pig
Why?
Old Aug 10, 2005 | 12:22 PM
cconrad's Avatar
So where is the immobilizer bit (chip, resistor network, whatever it is) located?
Old Aug 10, 2005 | 12:24 PM
dmbfan36_23's Avatar
Originally Posted by CJams
Why?
Why carry a key and a remote when you can carry just one! it kicks ass :-)
is it actually possible to guess? I've been trying a ton of things and no luck yet..
americanhonda, honda2000, hondas2000, hondamotors, hondaparts, hondagpec, honda, americanhondamotors, hondacatalog, hondapartscatalog, hondadealer, hondadealership
Old Aug 10, 2005 | 12:32 PM
CCColtsicehockey's Avatar
now I can have a honda key for my car. I dont use the factory remote anymore though cause I have an aftermarket alarm.
