My HID Fog Setup
Crusin Thur in my MR TSX!
My HID Fog Setup
I finally finshed my hid install on my fogs here is a pic of it. I will get one during the night. Tell me what you guys & gals think!
Sweet! What conversion kit did you use and what temp bulbs? Was there a problem fitting the bulbs and wire into the housing?
Cant wait to see the night results!
I will post pics of them hopefully tonight. The bulbs are the same temp as the ones on the headlights. I purchased the ballast off ebay for 150.00 they were for a Nissan Maxima. The install was only hard when you connect the bulb to the plug because it was little clearance but I manage get it to fit.
Yea! Post some pics and some details as well. Also, Can you run your fogs seperately from your headlights? Or is that a factory setup that you just used a conversion kit for?
I did this a few months back. I found it pretty easy. All I did was purchase the factory fog light kit, then I purchased this kit off ebay...... H11 HID ...This 4700K kit matches almost perfect. Pics are posted in my signature. Oh yeah and as far as the wiring...... Plug and play
Yo Ackman, u should come to the next Jersey meet, ur car looks hot....like those fogs a lot, thinking about doing that also. Really like the body kit too, looks good man keep up the good work......
Thanks I' ve been dying to go to meet but everytime there is a meet setup I can' t because I'm either to suppose to work that day or I am out of the state. Here is the pic of the hid setup at night.
Moderator Alumnus
I hope not! They were shipped from Florida they were on his car which he had a front end collision on which were replaced with two ones.
I am going to work on making the fogs run independly since I installed the fogs on my car I have and idea which are the two wires you have to work with. Should be simple since I did it to my 02 TL when I did the HID Fogs.
If you could actually purchase the OEM fogs and etc... with just the housing instead of the entire thing. Then just get an H11 HID conversion kit. Then instead of using the wireharness that connects it to the factory wiring (Since factory wiring wont let you run fogs independantly), get a switch from honda that goes into one of the spare slots that are underneath the sunroof controls. Now of course these fogs wont go off with the ignition unless you wire them up to the ACC wiring. But it could be done.
Unless you've figured out a way to do this on the TSX like you did on your TL? Please share when you've figured it out.
thanks
Hmm... you know... i just had a thought.
thanks
thanks
I'm the Firestarter
Wouldn't it be nice to see an HID DRL conversion? I'd love to have that...
And when you hit your high beams, you'd see the road with the full glory of 4 HID projectors.
