Mode actuator motor failure
Old Aug 7, 2025 | 08:27 PM
Petvvmd's Avatar
Hi, can somebody give me advice how to change a mode actuator motor. Thanks
Old Aug 7, 2025 | 09:05 PM
Is this the one you are referring to?
Mode Control Motor Replacement
1.Open the glove box. Remove the damper from the glove box, then let the glove box hang down.
2.Remove the relays from the bracket.
3.Disconnect the 7P connector (A) from the mode control motor (B). Remove the self-tapping screws and the mode control motor from the heater unit.
4.Install the motor in the reverse order of removal. After installation, make sure the motor runs smoothly.
Old Aug 7, 2025 | 09:17 PM
Petvvmd's Avatar
I have problem with removing a relay. Don’t find a latch
Don’t find a latch
Old Aug 8, 2025 | 10:57 AM
Show a picture of the area you are working on or the relay you are trying to remove so people know what you are talking about.
getakey
3G MDX (2014-2020)
Jun 23, 2018 04:21 PM
starboy2nv
May 3, 2010 03:49 PM
Nov 6, 2008 08:47 AM
