Memory seats question on 06 TSX
I just got my 06 TSX last week and had a question about the memory seat settings.
Does anyone know if the rear veiw mirrors are supposed to have memory on them to so that they adjust along with the seats?
I ask as I have a friend that owns a CL and he thought that the mirrors in the new TSX moved along with the memory seats.
FYI, the key mod we did for the 04-05 TSXs does work for the 06 TSX though... thanks to Lagasi for verifying it.
Thats a shame as my wife likes to have her mirrors facing in so much you can see the side of the car and not much of the road!!
C'mon, man! Row yer own.
Originally Posted by STL
You need to explain to her that doing that creates big blind spots that can easily lead to an accident.
Yeah, tell her how it is. Let us know how that turns out . . .
Swinger, just ask Lindy
I know the whole blind spot issue, and thats why I place the mirrors so that only the road is in veiw and not the car. I've also explained it to her numerous times but like swirlie said "Its a feeling of comfort of having your car as a point of reference". And I know its a bad reason, but women will be women !!
![HaHa](https://acurazine.com/forums/images/smilies/haha.gif)
she .................................logic .......................... ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Bwhaaaaa Haaaaaaaa (except for LuvMyTSX, who has proven to be cool and rational)
This is what one website said....
"Setting your mirrors
Here's the correct way to set your side mirrors to eliminate blindspots. Sit in the drivers' seat as you normally would, but move your head over to the left until it is resting on the side window glass. Now re-set your left mirror until you can just see a sliver of the left side of your car. For the right side mirror, position your head in the centre of the car (use the rear-view mirror mounting post as a guide) and then position the right mirror until you can again just barely see the right side of the car. That's it - no more blindspots.
However, it really isn't that easy. You will have to adjust your habits, and that will take a few weeks. At first you will be a bit disoriented when looking at your side mirrors, because that old familiar view of your door handles is gone. You now have a much wider field of rear-view vision, albeit without reference points. This takes some getting used to, but after driving with these settings for awhile you will quickly become very comfortable with the much wider range of rear side vision you now have."
IMO this is a "no win" situation. If she changes the mirrors after years of driving, and then has an accident...........well, let's just say it'll be ugly.
Well then, try doing it slowly. Set the mirrors without moving your head position. You'll get some benefit of a wider view, but not the full set. It won't be as dramatic a change. Once she's comfortable with that (maybe give it a few weeks), move the mirrors out further. It'll be smaller shifts, less disorienting initially.
Which reminds me, my mirrors need to be set wider. I haven't seen the sides of my car in the mirrors in years, but I've only recently heard of the "move your head out to the side" bit.
For years I set my mirrors on my door handles, despite hearing the abberviated description of setting the side mirrors in Tmetcalf's post. I just didn't get it.
Then I encountered Car Talk's explanation:
http://www.cartalk.com/content/featu...ors/step1.html
They discuss the method (leaning your head against the window, etc.) but I really didn't get it without the graphics. The Step 2 adjustment (using a row of parked cars) really helped:
Step 1: Start by setting your rear-view mirror as you normally would.
Then, lean your head all the way to the left so it touches the driver's window. From that position, set your left side-view mirror so you can see the back corner of your car. Now lean the same distance the other way, and set your right side-view mirror the same way.
Now, here's what happens. When a car comes up behind you, you should first see it in your rear-view mirror. But as it passes you (let's say on your left), you'll see it move to the left side of your rear-view mirror. And as its left headlight disappears from your rear-view mirror, it should instantly show up in your left side-view mirror. There should be no delay. It should slip from one to the other, so you can always see it.
Step 2 - Left-Side Mirror Alignment: Set your left-side mirror so that as soon as the passing car's left, front headlight disappears from your rear-view mirror, it appears in your left-side mirror.
You might need to make some slight adjustments to your side-view mirrors to make everything line up perfectly. And pulling up next to a line of parked cars (to simulate another lane of traffic next to you) is a good way to do that.
Step 3 - Right-Side Mirror Alignment: Then do the same thing on the right.
Step 4: End result? No huge blind spots.
Driving with the mirrors this way takes some getting used to. You have to learn to rely on your rear-view mirror first. And you'll have to get used to what your side-view mirrors are now looking at. But, the good news is that your blind spot should now be gone!
rockyboy
08-04-2024 10:35 AM
