Manual transmission fluid changed at 14k
Can't wait to drive
So I decided to change my manual tranmission fluid myself. I've heard from racing folks that it should be changed soon and frequently if you, um, shift "spiritedly." I noticed after changing my Manual tranmission fluid, my shifts are much smoother, gears go in with less effort, and overall great response..just like when the car was new, but better. Has anyone changed their manual transmission fluid also and noticed the same? Or, is it all in my head
Can't wait to drive
Very interesting, since it's more smoother and shifts are more precise. I will definitely change it more often now, since it's not too expensive to do it myself. I wonder why it's true, is it because the oil breaks down after a while, or the buildup of gunk or metal shavings?
Some of it might have to do with the kind of oil you replace the original with, but in most cases you won't get much of a change replacing the tranny fluid.
Can't wait to drive
I used genuine Honda/Acura Manual transmission fluid..you will need 3 bottles, but you'll only need 10% of the third bottle
(save for next time). First RTFM
, there are nice pictures and details on what to do in the owners manual. Some more hints..drain plug is in the "middle" of the car, you have to access it from crawling underneath the car (jack it up and use jack stands!!). The fill plug is on top, but it's a bitch to uncap. So, I used a transmission funnel (you'll need it) and filled it from the side plug (remove driver side front wheel) , which auto-spills when it's full. Make sure the car is level when filling the transmission (meaning not jacked up on one side), so you won't overfill the transmission.
![Angry Fire](https://acurazine.com/forums/images/smilies/angryfire.gif)
![rtfm](https://acurazine.com/forums/images/smilies/rtfm.gif)
![Racing](https://acurazine.com/forums/images/smilies/racing.gif)
Can't wait to drive
Originally Posted by NeoChaser
how do u change MT fluid?
it's just normal brake fluid right?
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
Mike Bertram
09-10-2015 09:27 AM
HeloDown
09-08-2015 06:51 PM
