Managed to push the TSX all the way
Originally Posted by PJS
In reference to your facetiousness about being 95, with 68 years of experience - the laws of nature tend to come into play. By that stage, my reaction times, thought processing times, eyesight, etc, will be the deciding factor in how safely I can drive - assuming I'm even in good enough health and mobile enough to still drive. But someone as smart as you would know that! (See, I can play the immature facetiousness game too!)
Oh, and on your comment about how you base everything on how you're still alive. Remember this: for everyone 1 of you, there are probably plenty more who have already learned their lesson either through injury or death if they were going 125 mph every so often. So, just watch out, and stay the heck away from me.
Originally Posted by IranBT
If you go back and read, I said the highway was empty due to the construction zone behind(Police had also blocked the highway. I didn't see why, but I think there was a small collision too).
Originally Posted by sidssp
How does the OEM tire hold up? I don't think they were designed to run over 100mph. If you run that fast often, the tread may get separated. Please be careful.
Originally Posted by minkl81
wow... another
created by IranBT..
he's banned now right? sauceman just found out that IranBT = Jasuklee.
created by IranBT..he's banned now right? sauceman just found out that IranBT = Jasuklee.
I'm not even from Iran and I've never driven past 160 km/h.
Hopefully my account gets reinstated
CL9 ABP
I was there this past saturday and hit some bad traffic due to construction haha.
Darn people are crazy on the QEW i'm always the slowest one and I still feel like im speeding...
Originally Posted by jasuklee79
Hey! I just wanted to set the record straight - that ain't me!
So you say that it's not you, then you go on to say that your account should be reinstated. Rightttt.
wow.....just saw this thread for the first time.
PJS, you're crazy no matter what you say. That speed is too fast on a public road, considering you got on that highway, I am sure other people could get on also. I don't care how good a driver you think you are, you shouldn't be doing that speed. There are too many unknowns about the road(oil, debris, bumps, potholes) as well as other drivers mistakes that i am positive that everyone who drives sees on a daily basis.
BTW, anyone else notice that the OEM tires PJS was driving with only have a speed rating of V, which states it is for speeds under 149mph?
Keep that speed on the track!!!!
They banned my account too
I don't even have a 6MT - mine's a 2005 5AT
Lurking in Azine is the only way I get thru my workday
Originally Posted by fadinglionhart
Since I don't want to push the TSX up to the limit in real life, can't we solve this using equations and stuff?
From what I understand, the speed of the car is proportional to the speed of the engine, right? So theorically, wouldn't the top speed just be a proportion of the RPMs at 6th gear (5th for AT) when the engine redlines? That's assuming you have a near infinitely long stretch of downhill straight road with little or no wind resistance.
Or am I incorrect with the way that I think engine speed/car speeds work? I'm curious to find the top speed of the TSX given the most advantageous environments where time isn't a factor.
So sue me if I'm a math/physics person; at least I'm safe.
Originally Posted by Joeys'TSX
Take it from a Mechanical Engineer...your engine speed/car speed logic is not even close to being accurate!
"wouldn't the top speed just be a proportion of the RPMs at 6th gear (5th for AT) when the engine redlines? That's assuming you have a near infinitely long stretch of downhill straight road with little or no wind resistance"
If the engine does 3000 RPM at 70 MPH in 6th gear, it will do 6000 RPM at 140 MPH in 6th gear. You can extrapolate what the vehicle's theoretical top speed would be at 7300 RPM: approximately 170.33333 MPH
If you had no rolling resistance or air resistance, the engine would have more than ample power to reach that speed.
Originally Posted by junktionfet
Actually his analysis is correct under the conditions he specified:
여보새요... 암 코리언 투 요... 낫 아이란이!
As I explained by PM, the ban remains, and this account will also be added to the ban list. Furthermore, you couldn't wait until you had cleared it with the mods and admins, instead you went ahead and posted right away, so that makes you a goner, permanently.
"wouldn't the top speed just be a proportion of the RPMs at 6th gear (5th for AT) when the engine redlines? "
"That's assuming you have a near infinitely long stretch of downhill straight road with little or no wind resistance"
Flaws with his argument...
1. As things move downward they tend to accelerate (ie gravity 9.8 m/s^2) this would increase the top speed parabolicly as time goes forward thus it would not be a linear calculation as he described.
2. Not all friction has linear resistance. Microphysics suggest most types of friction is nonlinear. The cars fluid resistance is definitely nonlinear (ie, oil, tranny fluid, diff fluid, other lubrications, etc)
2. The car would have to have perfect traction at the tires and other places throughout the drivetrain at the velocity range. No drivetrain slipping can occur and if it did it most likely wouldn’t be linear.
3. The car would have to be traveling in a fluidless atmosphere, ie. a vacuum.
I could go on but my point is if you make all the correct assumptions then yes theoretically his logic is correct but the errors introduced wouldn’t be a good representation of the true maximum velocity. His theoretical velocity (with ALL the correct assumptions) may be around 175 mph…when the true real life maximum velocity under standard conditions (sea level, 1 atm, etc) may be around 149 mph.
The problem is as you introduce assumptions you also introduce errors…eventually the calculation is far enough off to render it worthless.
Sweet guys I got my car to 185 today after I removed the speed limiter
Originally Posted by moda_way
I towed my 25' boat with the TSX this weekend. Talk about pushing the TSX to its limits.
I have a Mechanical Engineering education as well (that I've never used
). As much as I enjoy getting into really nerdy detailed-laden discussions, this is not really that kind of discussion.I understood the broad statement he was making. In the context of automotive discussions, it is fair to say that an "RPM limited top speed" is a constant. Regardless of the effect that gravity has, we can make a rule in our model that the car will not exceed the speed attained in top gear at the rev limiter. The time in which we reach that speed may change, but that is irrelevant here.
By using "front wheel horsepower", we are already containing the losses that occur from normal brake drag, wheel bearings, and friction between the gears, etc. So... again... if you remove rolling resistance and air resistance, or at least most of it, the car will reach the rev limiter in top gear.
My only assumption is that the enormous surplus of power from the engine will overcome what little resistance is left over. The validity of this assumption pivots on how you interpreted the author's intention when he said "little or no". Since this isn't a 600 level college course, I'm going to assume that he meant "near vacuum" conditions. Your interpretive mileage may vary.
ahhhh man thats weak I tow my trailer full of landscaping equitment with my tsx now that is pushing the limits.
[QUOTE=junktionfet]Wow all that and a reference to Microphysics and tractive quality.
You just added two more assumptions. You assume (or as you say "make a rule") the car will not exceed the speed attained in top gear at the rev limiter. The relative velocity will be influenced by traveling up or down a hill and can not be deemed irrelevant.
In addition, It's obvious if we talk about "front wheel horsepower" all the friction elements are enveloped but he didn't say "front wheel horsepower". Do we know what his front wheel horsepower is? That would also be difficult to calculate without introducing a large error.
Basically, you introduced two additional assumptions that he didn’t use. This solidifies my case…as stated his methodology of calculating top speed is erroneous.
My "rule" regarding the rev limiter is not an assumption. You cannot exceed the maximum programmed engine speed and still apply power, I don't care if you're on Jupiter or in free fall...
He didn't mention any kind of horsepower. I assumed "front wheel horsepower" for the very reason you cite... it is simpler to work with--otherwise we'd introduce a very large number of variables, many of which cannot be defined without spending extensive resources.
You missed my point on the uphill/downhill thing…it matters but if that’s not obvious then nevermind.
Point is if you do the calculation like he says it will NOT be accurate.
We can agree to disagree.
Originally Posted by jlukja
Correct me if I'm wrong but wouldn't VSA cut power to the wheels when in free fall?
