Maintenance Tune-Ups
Old Dec 7, 2006 | 12:14 PM
chullys's Avatar
7th Gear
I don't see it from the manual, but
any one have an idea when the maintenance tune is recommended?
I moved to Houston from New York this summer, and it's definitely not as cold,
but my car is noisier, and seems less power than the last winter.
I warm the engine up all the times, when I start in the morning.
It is the 04 with 70K miles.
Any Suggestions?
Old Dec 7, 2006 | 12:29 PM
LuvMyTSX's Avatar
I thought it was around 105k or 110k? I thought it was in the manual.
Old Dec 7, 2006 | 12:33 PM
jlukja's Avatar
From our FAQ section:
Maintenance
Normal Maintenance Schedule
For normal driving conditions
The "normal" schedule is fine for most drivers, even if they occasionally drive in severe conditions.
10,000 mi/16,000 km Scheduled Maintenance
Replace engine oil.
Rotate tires (follow pattern on page 276 of your owner's manual).
Check engine oil and coolant at each fuel stop.
Check and adjust valve clearance, cold engine, only if noisy.
20,000 mi/32,000 km/1 yr Scheduled Maintenance
Replace engine oil.
Replace engine oil filter.
Inspect front and rear brakes.
Check parking brake adjustment.
Inspect tie-rod ends, steering gearbox and boots.
Inspect suspension components.
Inspect drive shaft boots.
Inspect brake hoses and lines (including ABS).
Inspect all fluid levels, condition of fluids and check for leaks.
Inspect exhaust system.
Inspect fuel lines and connections.
30,000 mi/48,000 km Scheduled Maintenance
Replace engine oil.
Inspect drive belt.
Replace air cleaner element.
Replace dust and pollen filter.
40,000 mi/64,000 km/2 yrs Scheduled Maintenance
Follow 1 yr scheduled Maintenance cycle.
50,000 mi/80,000 km Scheduled Maintenance
Replace engine oil.
60,000 mi/96,000 km/3 yrs Scheduled Maintenance
Replace engine oil.
See information on maintenance and emissions warranty, last column, page 233 in your owner's manual.
Inspect drive belt.
70,000 mi/112,000 km Scheduled Maintenance
Replace engine oil.
80,000 mi/128,000 km/4 yrs Scheduled Maintenance
Follow 1or2 yr scheduled Maintenance cycle.
Old Dec 7, 2006 | 03:59 PM
aaronng's Avatar
Driver/Detailer
I wonder what everyone think these "tune ups" involve.
Old Dec 7, 2006 | 04:08 PM
PACman's Avatar
It involves a lot of my money and time; and I can't even SEE what they're doing. Perhaps I should of been an Acura Mechanic.
Old Dec 7, 2006 | 05:41 PM
aaronng's Avatar
Driver/Detailer
You can do it yourself.
Replace plugs at 60,000miles, throttle body cleaner on a rag, replace fuel filter under the rear seats and all the usual checkes, engine oil, MTF/ATF, clutch/brake fluid and coolant.
acuratl26
Apr 23, 2020 07:30 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
LeVeL
Oct 18, 2015 04:19 PM
polish_pat
Sep 30, 2015 12:22 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
