lug pattern question
Old Jan 20, 2009 | 02:12 PM
Itchy14's Avatar
6th Gear
I know the lug patern on a TSX is 14.3, correct? would I be able to fit wheels that were on a Mazda MDX which has a lug pattern of 14.5?
Old Jan 20, 2009 | 02:33 PM
MMsTSX's Avatar
JDM Addict
our lug pattern is 5 x 114.3
not just 14.3.
you would have to be more specific on the Mazda pattern.
and since when did Mazda ever make an MDX?
so do you mean Acura MDX?
or some other Mazda then?
Old Jan 20, 2009 | 02:48 PM
Itchy14's Avatar
6th Gear
I missed the 1... 5x114.3 the MDX is 5x114.5
Old Jan 20, 2009 | 02:52 PM
MMsTSX's Avatar
JDM Addict
strange.
never heard of a Mazda MDX.
never heard of 5x114.5 either...
so I guess I'm not the guy to help, I'm sure somebody else will
chime in soon and help you out.
edit:
do you have a link or whatever to what you are talking about?
and what is the offset and diameter of the rims? that is equally as important.
Old Jan 20, 2009 | 02:54 PM
Itchy14's Avatar
6th Gear
MPV not MDX... my mind was in the gutter... sorry
Old Jan 20, 2009 | 02:59 PM
MMsTSX's Avatar
JDM Addict
oh... you mean the minivan?
you want to put the minivan rims on your tsx?
from all what I can find, there is no 5x114.5, and the MPV is 5x114.3.
have any clue on the width and the offset of the rims?
or a picture of them at least?
Old Jan 20, 2009 | 03:10 PM
Itchy14's Avatar
6th Gear
they are 18 x 7.5 baccarat mirage rims that are comming off of an MPV
Old Jan 20, 2009 | 03:16 PM
Zhieson's Avatar
18x7.5 will fit fine. Post offset to double check.
IMO this wheels won't look good on a TSX. Probably didn't look that great on a minivan.
Old Jan 20, 2009 | 03:40 PM
sortudo7's Avatar
Site Lurker, Rare poster
^ If those are the rims then I agree, will not look good...anywhere lol. I would save for a diff set if I were you 0.02
And yea if an offset is not 5x114.3 then it won't fit our car but offset is important too so might wanna find that if you are set on getting them.
Old Jan 20, 2009 | 03:44 PM
MMsTSX's Avatar
JDM Addict
MPV has a 5x114.3 bolt pattern.
18 x 7.5 is just fine for the TSX, that's what I run on my rims.
so the most important question is what is the offset?
you need something between +42 and +55 to be safe.
the highest offset I can find for those rims is +42.
most I see are either +20 or +40, which you'll run into problems with both
if you are slamming your car.
chances are they are a +40 offset from what I see.
they will fit, but they will stick out a tad, or be flush with the fender.
which will mean no slamming the car, or heavily rolled fenders at the least.
but all of this aside, I agree with the above posters, those rims are not sexy in any way.
and not only that, they must be heavy as all hell, which will dramatically
decrease your cars performance.
Old Jan 20, 2009 | 03:53 PM
Itchy14's Avatar
6th Gear
its those rims but all black with chrome accents... i'll put one side on and see how it looks first... where can i find out about the offset does it say it on the tire by chance?
Old Jan 20, 2009 | 04:07 PM
LukeaTron's Avatar
Sometimes it's stamped on the inside lip, but not always.
Old Jan 20, 2009 | 04:20 PM
MMsTSX's Avatar
JDM Addict
correct.
on the tire?
no.
on the rim?
maybe.
it would be on the inside of the rim.
two common places are on the inner lip, like on a sticker or
stamp or something; and the other is on the inside hub
where the lug holes are. in between the spokes it would say
a number.
Old Jan 20, 2009 | 05:42 PM
Zhieson's Avatar
+42 is a safe offset but with 7.5" wheels you could go to mid 30s without dropping it too much. +42 is a good guideline tho.
I have 8" wide with 42 offset with 1.5" drop without a problem. 7.5" with +35mm offset would be close to the same.
Old Jan 21, 2009 | 03:06 PM
Itchy14's Avatar
6th Gear
thanx alot to all that gave me the heads up... i agree with those of you that said the all chrome rims probably wouldnt look good, however the black ones look great on the car which is silver... as far as weight goes, the stock wheels with about 5-10% tread left weigh 45.2 lbs and these with new tires weigh 46.0 lbs...i'll post pics up soon, to see what ya'll think...
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
kev87a
Oct 18, 2015 02:03 AM
navtool.com
Sep 25, 2015 05:15 PM
