Left Right adjustment on HID's
Old 08-12-2007, 03:38 AM
CGP Ebony
xenonhid's Avatar
I tried searching but did not get any results.
After lowering my car, I had to raise the HID beam higher. That was done easy.
However, now I noticed that the beam pattern is not equal, the drivers side is off to the right side.
You can tell visually when you look straight ahead at the front, the drivers side beam is brighter than the passengers side and is not equal.
I know you can raise/lower the low beam.
Is there Left/Right adjustment for the low beam?
Old 08-12-2007, 04:57 AM
Let me help you!
SoCaliTrojan's Avatar
Are you sure it's not due to the cut-off? Each beam pattern should look like this:
Code:
                 ________________
________________/
Thus, the beam is higher on the right side (to prevent you from blinding oncoming drivers)
But to answer your question, I believe there should be. Just like moving it up and down, there should be another set of adjusters to move it left and right. Try looking around and see if you can find it. I believe I did see it last time I adjusted my lights, unless if it's only for adjusting the high beams (ie: tilting the headlights)
Old 08-12-2007, 02:16 PM
CGP Ebony
xenonhid's Avatar
Looks like there is no adjusters for left and right alignment. Can someone else confirm this as well? Thanks
Old 08-12-2007, 05:25 PM
TSXHunter05's Avatar
how do you adjust them up and down?
LoneRonin
01-04-2016 01:03 AM
ripit
09-26-2015 06:19 PM
TL14
09-24-2015 04:37 PM
flybyglass
09-24-2015 01:12 PM
Quick Reply: Left Right adjustment on HID's
