Led wiring
Led wiring
I want to wire led lights underneath the wells for your feet in the front.. I want them to go on when you open the doors and maby also be able to manually just turn them on. I need to know where to wire them to and what parts I need to buy.
http://www..com/forums/1st-gen-car-c...own-diy-2.html
that's the thread from the tsx club that shows you how to do, just did it myself, very easy and straightforward
Site Lurker, Rare poster
There's a thread on here about it too. Search. I have them and love them. Doors have to splice into a connector in the back of the foot panel fuse box. I also wired them to turn on with lights. If you want something you can manually turn on you can do what I did or add in an SPDT switch as stated in a thread already on here.
https://acurazine.com/forums/showthr...ambient&page=4
use the green/red wire on the back of the fuse box for ground. It is pin-4 of this plug here:
Tap fuse#6 for +. Most people use an add-a-circuit fuse tapper.
I wired it up to the light inside the "cd holder" and that light turns on when you turn the headlights on.
So lights are always on with the headlights and if you leave your hid's on after you park they will be on when you unlock the car.
SUPRMN84
10-07-2015 09:46 PM
