Just Bought An extra Remote need help programing it
Old Apr 29, 2007 | 08:48 AM
careless55's Avatar
Need Help In Programing it
Old Apr 29, 2007 | 09:44 AM
cpone's Avatar
Obtain all remotes.
Switch ignition ON.
Proceed as follows,
Within 4 seconds: Press LOCK or UNLOCK on first remote (unprogrammed).
Within 4 seconds switch ignition OFF.
Within 4 seconds switch ignition ON.
Repeat procedure twice.
Within 4 seconds: Press LOCK or UNLOCK on first remote.
System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds...
Press LOCK or UNLOCK on first remote allowing doors to lock and unlock once.
Press LOCK or UNLOCK of each remaining remote allowing doors to lock and unlock once as each remote is programmed.
Switch ignition OFF
Remove key.
Old Apr 29, 2007 | 11:51 AM
JDMballer's Avatar
7th Gear
The codes of up to four transmitters can be stored into the keyless receiver unit memory. (If a fifth code is stored, the code which was first input will be erased.)
NOTE: It is important to maintain the time limits between the steps. Make sure all doors, the hood and the trunk lid are closed, and windows are up.
1. Turn the ignition switch ON (II)
2. Within 1 to 4 seconds, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the driver’s side of the dashboard.
3. Within 1 to 4 seconds, turn the ignition switch OFF.
4. Within 1 to 4 seconds, turn the ignition switch ON (II).
5. Within 1 to 4 seconds, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the driver’s side of the dashboard.
6. Within 1 to 4 seconds, turn the ignition switch OFF.
7. Within 1 to 4 seconds, turn the ignition switch ON (II).
8. Within 1 to 4 seconds, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the driver’s side of the dashboard.
9. Within 1 to 4 seconds, turn the ignition switch OFF.
10. Within 1 to 4 seconds, turn the ignition switch ON (II).
11. Within 1 to 4 seconds, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the driver’s side of the dashboard.
12. Confirm you can hear the sound of the door lock actuators within 1 to 4 seconds, then push the transmitter lock or unlock button again, or the code will not be stored.
13. Within 10 seconds, aim the transmitter (up to two additional ones) whose codes you want to store in the keyless receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and remove the key.
15. Confirm proper operation with the transmitters.
NOTE: Once the programming mode is entered, the remote button must be pressed a second time. If the button is not pressed, or if the ignition switch is turned OFF, the programming for all remotes will be cancelled.
Old Apr 29, 2007 | 02:48 PM
moda_way's Avatar
^^Um... the computer handles 3 transmitters. On the 4th program, it erases the oldest or first transmitter programmed in. FIFO (First In, First Out)
Old Apr 29, 2007 | 03:04 PM
asaldworth's Avatar
Smile
Glad to see another accountant.
Old Apr 29, 2007 | 06:49 PM
moda_way's Avatar
Just a business man. I passed accounting by the skin of my teeth. It wasn't until I started using it in business that I actually understood and became proficient with it.
rockyboy
Aug 4, 2024 10:35 AM
oyayjoe
Jan 1, 2019 10:17 PM
nanos
Nov 12, 2015 08:41 PM
Sep 17, 2015 09:01 PM
Trplezero
Sep 3, 2015 10:25 PM
