Which JDM headlight do you prefer?
JDM Addict
06-08
I don't like the orange turns.
If you're buying a JDM light so you don't have orange anymore
in your headlights, then go with 06-08.
The 04-05 ones only change out one orange piece, the sides.
There's the ones from ebaY to consider too though...
http://cgi.ebay.com/ebaymotors/04-05...em380008254810
http://cgi.ebay.com/ebaymotors/04-05...em300209149934
http://cgi.ebay.com/ebaymotors/JSPEC...em310034204580
These ones are clear all the way through, and dirt cheap!
JDM Addict
They're not JDM, just look at them.
They're some sort of knock off, but they just may work good.
Nobody knows yet, we're all too skeptical to buy them.
I just paid out the rear for 06-08 JDM lights with Demon Eyes installed on them.
These ebaY lights would have saved me $500.
But who knows how good the quality of projectors are...
And if the beam pattern is indeed JDM or if it's a USDM pattern.
boost owns
Depends on the color of the car.
For a white, silver, or CGP TSX, 06+.
For all other colors, I prefer the 04/05. CGP could actually go either way as I love how my 04/05's look on my car.
boost owns
Originally Posted by LaZyPiGgY
Just clarifying, when you say JDM and USDM beam pattern, I'm assuming that everyone who buys JDM headlights don't mind blinding incoming traffic since JDM beam pattern would be raised on the left side, am I right?
As Heeltoe once said, "If you end up in hell, it won't be for running JDM headlights."
Former Sponsor
For me it really depends on the color of the car. Some look better with the grey sides and some look better with the blue.
I STRONGLY RECOMMEND AGAINST swapping the projectors though. It really is not specifically necessary and you risk doing damage. It is better to get the EDM headlights if you can. They look the same as USDM but come with LHD projectors.
Marcus
Marcus
JDM Addict
You mean EDM looks like JDM, right?
The problem is finding EDM lights. Not as easy as it may sound...
Or at least it wasn't for me and several others.
Maybe we're all missing something though...
Former Sponsor
They look identical actually.
I have EDM 04-05 in my "list of stuff I can get if you are willing to wait for it." I am working on getting 06-08 now.
http://www.heeltoeauto.com/Honda-Gen...7-pr-5046.html
Marcus
Marcus
JDM Addict
Marcus
Marcus
Nobody has them, nowhere to get them.
For a price worth paying that is.
If they were readily available, I would have no need to buy JDM.
But I couldn't find any 06-08 EDM's for the life of me, so I went with
what was available.
Oh well, I'll just deal with my backwards beam pattern for now...
Swapping the projectors is an extremely easy, 10 minute task. I've done no less than a dozen pairs now. Yes, you have to pry it a little bit, just use common sense and its not a problem.
EDM heads are next to impossible to get, unless you grab them off ebay.de or another euro country. I tried that at first, but ended up Heeltoe'ing some JDMs and swapping the projectors.
Honestly, someone should just bone up for the JSPEC knockoffs and swap your stock projectors in. I bet it works just fine!
Oh, and thread moved.
06-08
mmmmmm....
06-08
I actually got the 275 ones off of ebay because my passenger side had collected moisture due to bad sealing on my part , and so instead of paying 400+ to Acura to get a replacement I just decided to get these and swap both out. (Not to mention that 400+ would be just for that assembly alone, I still had to replace the ballast because it blew)
I am putting them on tomorrow, and will take pics and post them. It came with amber bulbs because the turn signals are clear, but I don't like that look so I ordered some amber led's to swap them with, and I already had replaced the side markers with hyper white, so we will see how it looks
Dude, i cant wait to see it! Please post pics asap!!
i have an 06 but i like the look of the older lights
i think completely clear doesnt look good against white, i like the litte orange blinker
i just picked up a complete set of 05 jdm lights (bulbs ballast etc) for $650
you don't have to remove the complete projector
just unbolt the projector and leave it in, then remove the little shield in the center of the projector and swap it with your oem usdm one
then you have jdm lights that function correctly
very easily done
very easily done
Former Sponsor
very easily done
very easily done
That sounds much safer
def. let us know how the lights are roxxor...i contacted one of the ebay buyers of these and he got them and said the construction and quality look good...he sent them to Advance Automatic Concept to get angel eyes installed then will put them in when he gets them back..
Originally Posted by S14 n Tsx
I just can't trust those ebay crap. They looked like someone photoshop the stock orange sidemarker to clear one. Unless they provide real picture, it is hard to believe it. I think it's just waste of money... rather save up and get the legit one! You can find used 04-05 for pretty damn cheap. I sold mine for $350 shipped so...
Plus keep in mind when you buy cheap lights that are real OEM often times they aren't silled right. Then your lights are going to be fogging up or even filling up with puddles of water in them. Not good. I bought Ebay lights for my last car and they litterally would have an inch of water inside after it rained.
Pay the money and get the real thing. The money is worth it.
OK, finally got them on and got some pics. Out of curiousity, did the size of the HID ballast change from the 04-05 models to the 06+? Because I have 06, and when I got the headlights realized the box said 04-05, the only issue I had was the ballasts not fitting in the spot on the bottom of the headlight so I had to zip tie them on. Other than that, everything works great, and I doused them with water to check for leaks and nothing happened, so I will keep an eye out for leaking.
To see what mine looked like cleared before the leak started on that which blew my ballast, here's the thread https://acurazine.com/forums/showthr...hlight=cleared
On with the pics
On with the pics
The beams are definitely not usdm, but I'm not sure if they are JDM or just out of alignment because there isn't a line per se like there was before. I was driving on the highway at night and my headlights were lighting up the overhead signs, but I don't think I will change it, kinda like it that way.
The ballasts were the only issue, other than that everything fit right up.
JDM Addict
hmmmm....
Is there any chance you can take a picture of the beam pattern late at night?
So we can see what it looks like?
you're awesome, thanks for the info so far.
So... just buy these and put in your stock projectors. I don't understand why people aren't doing that!
And yes, 04/05 and 06+ used a different physical ballast. Everything else is the same (fitment wise).
JDM Addict
I understand quite easily.
Opening and dismantling several headlights is not a job most want to do.
If there was a comprehensive DIY, or if more people had done so easily in the
past and documented it, you might see more willing to try.
But most are not.
Our lights are very expensive, and if condensation becomes an issue from a
poor job resealing the lights, it could cost us lots of money.
And then it wouldn't seem too worth it.
Basically, fear of messing it up.
That's why it's not being done much DIY style.
Welcome to Olliewood
But most are not.
But most are not.
