IPOD/ AUX Input
IPOD/ AUX Input
okay, well i cant seem to find a thread to ressurect so i guess ill make a new one here.
it seems that dension has came out with a new connecter for the ipod? is that the one i want? Is there another brand that works similarly? Does dension allow for me to buy a cord to plug in red n white rca cables so if in the future i decide to get rid of the ipod i can connect another music source?
what about mounting options? did any one buy that adapter? did any one make something on thier own?
thanks alot guys.
i plan to order this stuff tonight so i can get it installed b4 i get off spring break.
thanks alot guys.
You'll want to check out: https://acurazine.com/forums/showthread.php?t=3148
Don't know if there's a solution for 2005 (XM) + NAV.
nooo not nav nor xm, well possibly xm but im saying if down the road this ipod goes kaput and i get say a nomad or something else and it doesnt have that ipod connector is there RCA inputs so i can just use a y adapter?
Your best bet if you want to have RCA inputs is to go with a Soundgate SNHOND3 or Blitzsafe adapter. Details for the installation of the SNHOND3 unit can be found in the link posted by bryhogan above. The same instructions would go for the Blitzsafe unit also. The unit that Denison sells, from my understanding, is a SNHOND3 unit for the RCA inputs and their unit which allows you to use the steering wheel controls to go through playlists.
My set up is just the SNHOND3 adapter and Belkin Auto Kit to keep my iPod charged while I drive. I just use the iPod controls to flip through the songs or just set it to shuffle. But its basically the same as Schalliol's set-up which can found in the link above.
hmmmm, looks like im going to need to call them. atleast then it would either be someone who knows the product that they are going to sell me, or then be thier problem if its wrong .....
who knows, good ideas tho! now i need to figure out how to mount this thing
called dension, they said they dont offer a kit for the TSX at the time.... they said in a month theyll have the verion 2 out? but on the page they say they offer it, any one else with this problem?
I just bit the bullet and ordered an IceLink. However, I think I will sell the SNHOND adapter (check the black market board in a week or so!) that comes with it and buy one of the premade cables, since I don't have access to any soldering tools here and the cost of doing it myself would be greater than just buying another.
I already have the SNHOND3, which connects to a Belkin auto adapter, so my iPod stays charged. If I add an ICELink to the SNHOND3 (as I read in the FAQ thread) I assume I won't need the Belkin adapter, since the ICELink connects directly to the iPod.
Does the ICELink provide charging as well as the ability to use the steering wheel controls?
they said when i was going to order it that they stopped making the verison 1 and the v2 (plus) will be back out in a month.... someone else had that problem, he wound up calling them and they said the month or so and this is way b4 xmas
I picked up a Sony-iPod ICELINK on ebay and hooked it up to my SNHOND adapter, and the audio worked fine, but none of the controls on the steering wheel or radio panel seemed to affect the iPod operation.
The Dension ICELINK model is "3GS5 for iPod 3G"
The SNHOND model number is "SNHON01200"
Does anyone know why this isn't working? Thanks.
So I am a little confused about this. I have the 2005, with Nav, and XM, but I am NOT going to renew the XM. If I don't need the XM, is there ANY problem hooking up an IPod AND having the wheel mounted controlls operate the unit? If this is OK, what products do I need? Icelink, etc..? Does this installation viod any part of my warranty (cutting into the wiring harness,etc.)? Thanks.
If you are ok with losing the XM, it is fairly easy to install the IceLink. In fact, in a few weeks, Dension (the makers of the IceLink) is supposedly releasing a new version for the TSX that will completely eliminate 75% of the work needed to use the IceLink with nav, thus making the install 100% plug and play.
Yippee! In truth, I have not been very impressed with the sound quality or selection of XM. Not that FM is better, just that I can't see paying for XM, and still listening to someone else's chioce of music, when for the same $ as a several year subscription to XM, I can get an IPod and adapter and pick all the tunes myself. OK, now I am a confessed control freak.... Any support groups?
I've had the Dension ICE-Link in my '05 TSX 6MT non-nav for about 8 months now and could not be happier with the sound quality and flexibility. It is extremely easy to install, and you have the ability to update the system. So, if they find a way to display the ID3 tag, then you can update the software. (However, from my conversations with Dension, I don't know that this is likely to happen). Nonetheless, with it you can use the both the stearing wheel and dashboard controls, it charges your iPod (up to 2 hours after turning off your car) and you have the option of using their interface or the iPod interface.
While it is a pricy unit at almost 200 bucks, I think it is well worth the up-front cost to get the outstanding sound quality, variety of integrated controls, and ease of instalation.
While I'm happy with the iPod, I would like to be able to hook up my XM once again, and remain on the hunt for a Y-connector/switch that will allow me to use them both. So far my search has lead me to a Y-connector without a switch (P/N 08A31-0F1-000). I haven't been able to find a definative link or discussion about this piece in all the XM/iPod forums, so if anyone has any input, I'd much appreciate it.
USA SPEC PA11. w/ y-cable if you have navi. You'll get XM + RCA aux inputs + iPod charging / control cable so you'll have steering wheel controls like with the Dension. It also allows direct iPod control (which I prefer over steering wheel controls).
Check out the A/V section, we've been discussing this unit recently. I have one on order to check out how it works with the 2006s.
I ordered the USA SPEC PA11H2Y for my '05 6mt non-navi from Crutchfield on Monday and it was waiting for me at my door after work today, just 2 days later. Had it working within minutes, although I uninstalled every thing to buy a RCA-to-3.5mm cable and drill a hole through the back of the tray. It's great, RCA output, ipod dock connector, and you can still use XM if you want.
Once you remove the console above the "not an ashtray" console, just use a mirror and a flashlight to find it. It's behind the radio, a bit to the passenger side from the middle, IIRC.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
