iPhone 4S and TSX Handsfreelink
Old Oct 6, 2011 | 07:16 AM
mikw4's Avatar
I've been told iPhone 4 worked great with the Acura HFL. But with bluetooth 4.0 in iPhone 4S, will it function properly? I have an 07 TSX w/nav for reference.
Old Oct 6, 2011 | 04:33 PM
JPSMAN's Avatar
The BT 4.0 standard is backward compatible, so it should be fine. I guess we just need to have someone test it out just to be sure.
from CNET:
One of the lesser-known facts to emerge about the iPhone 4S yesterday is that it is the first phone to launch with Bluetooth 4.0, the latest version of Bluetooth. Not many products are available with Bluetooth 4.0 just yet--in fact, two of the most recent products to ship with Bluetooth 4.0 are also from Apple: the MacBook Air and the Mac Mini. Bluetooth 4.0 is backward-compatible with all other versions of Bluetooth, so you can pair existing Bluetooth headsets with the new iPhone without a problem.
Old Oct 14, 2011 | 12:44 PM
mikw4's Avatar
Thank JPSMAN. I hope you're right.
Anyone pick up the new phone this morning and try it?
Old Oct 15, 2011 | 02:52 AM
acura_ak's Avatar
Just paired the iPhone 4s with my TSX and so far it seems to work great. Was able to make calls with no problem.
Old Oct 17, 2011 | 09:56 AM
patmd's Avatar
6th Gear
Unhappy Problem importing phone book
I paired the phone with not problem.
Then I went the INFO menu to import the phonebook. It said it was "importing" but was still importing after 10 minutes. I'll try later but don't recall it taking that long using my old iphone 3G. I hope it isn't a problem with the iphone 4S since I've deleted my prior phone book.
Old Oct 17, 2011 | 10:47 AM
evocative's Avatar
Getting the same issue here. Takes about 10 minutes then it fails.
Old Oct 17, 2011 | 07:16 PM
evocative's Avatar
UPDATE: It takes little more than 30 seconds with my iPhone 3G but fails with my 4S.
Old Oct 23, 2011 | 12:27 PM
SENATOR's Avatar
Connected
Any fix for this? Same problem with my 4S and 11 MDX.
Old Oct 23, 2011 | 03:05 PM
SENATOR's Avatar
Connected
I found the solution to this on another website. Basically, you sync up your Bluetooth with the car like normal. When you go to sync your phonebook as you normally would, allow it to try and then go into your iPhone 4S settings into the general tab, then into your Bluetooth settings, and click/touch the button that actually says HandsFreeLink. It will temporarily kill your Bluetooth connection but suddenly your iPhone's contacts will import into the navigation system. Problem solved!
tsx_boy
Dec 13, 2019 08:33 PM
mlody
Dec 4, 2019 02:11 PM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
ceb
ILX
Sep 27, 2015 10:56 AM
Eggs999bacon
Sep 24, 2015 10:08 AM
