i-VTEC in a V-6?
i-VTEC in a V-6?
Why hasn't Honda made a V-6 with i-Vtec yet? Mabye they have...I don't know...that's why I'm asking....but it just seems strange that the new TL, for instance, has simply a VTEC motor. While my technical knowledge of how the two systems differ is limited, I'm sure there must be a way to implement it in a V-6.
the TL is still using the older J-series motors(which btw are VERY awesome motors), which have been out since 97 I believe in the CL's. As opposed to the present TSX, RSX, and Civics which are using the newer K-series motors which have I-Vtec, as opposed to the older B and D series motors. I'm sure the next V6 series motors that Honda comes out with will have I-Vtec or something similar.
Re: i-VTEC in a V-6?
The JDM Inspire does get the i-vtec with its V6 while the Honda Accord sold here in Australia (manufactured in Thailand) only gets the normal vtec. I'm not sure about the Accord in the US though
Honda's current V6's on the market are currently Single Overhead Cam engines while their I4's are DOHC. Right now, i-VTEC only works on DOHC engines. They either haven't spent the money to rework it in order for it to work on SOHC engines or they don't want to overhaul their V6's since North America is about the only place they use 6 cylinder engines in regular use
http://www.vtec.net/news/news-item?news_item_id=112340
So....are we expecting next year's TL to have i-Vtec....or is it just the 3.0 liter in the Inspire that can do it? It seems strange to me why they would not offer this new "variable cylinder management" in the new TL.
if the i-vtec really helps improving fuel economy in a V-6, while improving acceleration too, i would be first in line if Honda puts it out in the next gen TSX or in their future cars if the styling is nice.
Originally posted by jumpper
Here is what I found from www.vtec.net on JDM Inspire...
It just says it was added to the engine which doesn't have i-VTEC. Even still, if i-VTEC is so much better, why does it only add 7 more hp?
We don't use i-VTEC in engines that aren't 4-bangers. We use them in the K-series engines because it gives these 4-cylinders something they're not used to: a flatter powerband with more low-end torque. We don't use them in V6s because they don't need it (and they can't use it because they have timing belts instead of chains). VTEC engines have SOHC designs on most of our engines now, and the i-VTEC ones have DOHC setups. You have to have a twin-cam engine to utilize i-VTEC. Yes, the "i" stands for intelligent, and i-VTEC = VTEC + VTC (variable timing control). VTC is a system that makes the intake cam constantly variable, producing smoother torque availability.
Exactly what Kurt said. You have to be careful because Honda is also calling their cylinder deactivation system on some v6s 'i-vtec' which has nothing to do with VTC or performance, just mpg improvements.
joflewbyu2
Aug 18, 2019 10:38 PM
Pham Alvan
Mar 16, 2016 09:17 AM
gavriil
Jun 23, 2003 11:02 AM
