How to test a relay?
Old Dec 17, 2009 | 01:38 AM
str8 tsx's Avatar
I think one or more relays has gone bad in my car, the wipers do not work and the HVAC fan is not blowing. What is the easiest way to test the relays in the fuse box under the hood? Thanks!
Old Dec 17, 2009 | 09:26 AM
thunder04's Avatar
Sweet!
Can you swap it out with another relay (assuming there is another one...I'm just guessing here) to see if that resolves your problem?
Old Dec 17, 2009 | 12:39 PM
BlackAccordion's Avatar
The relays should be 12volts, try to get 12v from somewhere and apply to the relay input line, then it should open or close. If not, the relay is most likely faulty.
Old Dec 17, 2009 | 08:29 PM
nbtx's Avatar
still plays with cars
You need a factory service manual for these issues. Follow the diagnostic trees for each problem.
Old Dec 19, 2009 | 04:11 AM
aCUREa's Avatar
There are many different kinds of relays. In order to systematically test one, you have to specifically know how it works internally... or like nbtx said, the manual will specify a diagnostic procedure.
Did you check the fuses?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
