How to rev engine from under hood?
You can't even if you could. The rev limiter is at 4K when in neutral or I guess park for autos. So you never could ge to Vtec range even if you could manipulate the Throttle Body. Sorry
Originally Posted by CGTSX2004
5k rpm rev limiter while car is stopped. If you really want to hear what the car sounds like in the vtec range, stand somewhere and have a friend drive your car near the redline by you.
Did you say let a friend drive my car?
step 1- remove hood
step 2- have someone drive your car
step 3-open sun roof
step 4- climb through sun roof on too front of car
step 5- listen to reving engine
Disclaimer- stuckthrotle is not responsible, loss of fingers/ limbs, burns,roadrash fractures caused by this procedure.
you can rev the engine under the hood. the throttle body linkage is out in the open, but you will not be able to hear vtec. instead you will hear the sound of your car cutting fuel off to the car @ 4k
Bye TSX, hello domestic?
Originally Posted by JTso
The TSX has DBW so no direct linkage on the TB. However, you still can rev the engine by removing the Accelerator Position Sensor cover on the firewall and rotate the cam.
09-17-2015 09:01 PM
Mike Bertram
09-10-2015 09:27 AM
