how to remove wiper blade arm?
cant figure out how to remove the entire wiper blade arm (pass side). my old maxima had a little latch that you poress, where the arm connects to the knob on the cowl. some help?? thanx!
The arm or the arm and the motor? if you want just the arm best thing to do is pop the hood, you will see a little rubber cap over the arm, once you pop that off you'll see a bolt, (18mm) just remove that bolt, pop the wiper blade back and it should come right off! same thing for passanger side.
its weird, only the drivers side has that rubber cap, the pass side just has the metal arm, no cap over it??
mlody
12-04-2019 02:11 PM
adreano17
09-29-2015 08:48 AM
