How often do u check Tire pressure psi?
I decided to check the tire pressure for the 1st time on my TSX since I got it new back in Jan. To my surprise the Acura dealer set my front tires at 38 psi and the rear ones at 34 psi? Why? So, I just leveled them all to 33 psi. After leveling the tires, I could feel a better ride. What do you guys set your tire pressure to?
Re: How often do u check Tire pressure psi?
33 psi in each tire is OK, but the recommended is 32 front, 30, rear.
Also remember that you shouldnt check within 4 hours of driving the car, because the pressure during that time will read higher.
Originally posted by Dan Martin
33 up front 35 in the back. I check biweekly if not weekly.
along with having a better ride, unfortunately i felt like the gas mileage was also affected, not as good mileage now at 33 psi than when it was at the acura's default level of 38/34.
Photography Nerd
I think the car feels more neutral set up that way. I even it out to 34 all around when I go on a long road trip. It's possible that you might pick up some mileage with higher pressure but it's going to be a minimal difference.
I should check more often, but usually about once a month.
I've got it at 35 front, 33 rear and have noticed a jump in fuel economy from 32 front and 30 rear. But it's very minor. Luckily the change in ride quality is also minor so I'm going to take what I can get.
Photography Nerd
Yep and it's on the list. I'm waiting for a little more choice in the market before I make my move. My first priority is some summer rubber though. These all seasons have got to go....
well, for now i'll leave it 33 psi. yeah u guys are right it's really minor about the change in the gas mileage. for a preppy 4 cyl sports sedan i'm happy with the improved ride and still low prices on the gas fillups thankfully since gas prices are going to prob $3.00/ gal by summer for 93 octane i heard? ridiculous!
A-TSX Driver...
Re: Re: How often do u check Tire pressure psi?
Nuke
Re: Re: Re: How often do u check Tire pressure psi?
Originally posted by hondaboy_tsx
Why the different pressures front/back? Does it have something to do with more weight in the front vs. back?
I check my pressures once every 1-2 months, normally on a weekend morning before the car has been driven or when there is a major shift in outside air temp.
HeloDown
09-08-2015 06:51 PM
