How to adjust the clock!
How do you adjust the clock?? I cant seem to find my owners manual. I see the Hour and Minute buttons but cant seem to figure it out. thanks.
All you need to do, it select daylight saving time, and hit reset. If you are going to do it manually, the time is displayed in the upper right hand corner. Use the - and+ to adjust the time and this will be displayed on the MID.
mmmmmm....
push and hold the button on the right(the one that adjusts station frequency). after a couple of seconds the clock should start to flash. the push the H or M to adjust the time.
Make a hole, coming thru!
