Hit a pothole, warranty question
I let my brother drive my 07 TSX AT w/ nav yesterday. We hit a decent size pothole at around 55mph on our way to Manhatten. I didn't think anything of it at that time, but on the drive back to VA I felt like the car had a slight pull to the left. On the way to work this morning, left turns on the steering wheel feel less rigid than on right turns. I'm pretty upset (mostly at my brother) and I know it will distract from the fun of driving unless I get it fixed asap.
My question is, the car is only a few weeks old. How should I go about getting this checked out?
- Go to an Acura dealer? If so, say I hit a pothole or just say the "wheel alignment is off" Is this covered under warranty?
- Go to NTB or a speciality place to get wheel alignment/rotate tires?
Hardly a fault of the car's that you/he didn't see the pothole, is it?
Maybe it's time to use the US's favourite action - lawsuit!
Whomever is responsible for the roads wherever this occurred, then you need to file a claim against them for not properly maintaining them. Make sure you've a photograph of the hole and measurement of depth at the least.
Thanks for the jackass reply. I'm just asking if it is covered under the warranty or if I have to pay out of pocket. I don't have the warranty readily available right now to make a reference.
Off roading in his
Registered Car Nut
Originally Posted by sidssp
You are assuming the pothole caused alignment problem but you don't really know that for sure. I would just tell the dealer the car is pulling to the left and ask them to take a look. If it is indeed alignment problem they will most likely realign it for free since the car is so new.
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
...and don't let your brother (or anyone) touch your car ever again!
built for speed
You're calling the second poster a jackass. That's ludicrous! Your brother hit the pothole, hardly a defect of the car. Why should the warranty cover it. Stop looking for help when you don't deserve it, it breaks the system. Just my 2 cents.
Jackass replies aside, alignments are a consumable item, and aren't offered free from the dealership, in my experience.
However, many places (I think NTB does this) will give you a free alignment 'check', which is a readout from their alignment computer, and then try to sell you alignment services and everything else under the sun. You can use it to judge how far out of spec your car is and whether you want to pay to have it done.
just to clear something up. Alignment is free up to 12k miles it's in the manual. Pull to the left is normal. I have the same pull and alignment will not fix it as I already had 2 of them done. TSX has sensitive steering and now you are more sensitive to the steering because you feel like it wasn't there before you hit the pothole. The "feel" you have will go away after you drive the car for a few months. Enjoy!
Owned 06 for almost 3 month.
Registered Car Nut
My TSX doesn't pull to either side... i don't think that would be normal.
However, depending on the crowning of the road, the car could pull to either side. Passing lane (where I normally am) results in an impression the car is slightly pulling left. however, if I go in the slow lane, the car slightly pulls to the right.
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
Your brother hits an obstacle in the road (could've been a dead badger) and you ask if driver error is covered by warranty?
What planet did you come down from recently?
Maybe it's your brother you should be calling a jackass for not paying attention to the road, or driving too fast for the distance he could see in front.
If the pothole was indeed unavoidable, then as I've already pointed out, you need to take photos of the defect, and report this to the highways agency or whatever dept. of the city is responsible for maintaining the roads.
Should I repeat that once more for it to sink into your skull, or have you got the message by now!
2 further points I should make:
1) It takes a jackass to know one, and
2) Ask a jackass question, get a jackass answer.
Over to you dumb and dumber!
Oh, and on the issue of hoodwinking the dealer into believing the car magically developed a problem - that's something you'll have to clear with your conscious, since you're the one going to have to live with the deceit.
check your warranty book. they cover wheel balancing and align,ent for 1 year or 12,000 miles. granted, it was your fault, but they covered it for me twice with no questions asked.
also, alot of tsxs have alignment problems anyways, so they will think its that.
Yikes. It's worth a try to take it to the dealer and play stupid. Don't have any qualms about this either. After all, the pull might not have been due to the pothole. Good luck!
mmmmmm....
Do I have to bring my car to the same dealer I bought it at, for them to honor my warranty? (Bought it in NY, live in VA)
Regardless, thanks for the replies guys. You've been very helpful. I'm bringing it into an Acura dealer Friday, we'll see what happens.
To the first reply, I didn't know you were being serious. It sounded sarcastic to me and a little far fetched. I was having a bad day at the time of my post, sorry about the jackass comment.
Later.
Later.
No, any dealer can apply for warranty repair remuneration or go-ahead from Acura.
Hey, we all have off days - no biggy. No harm no foul as you'd say.
I was being facetious when I suggested you sue the city for any expenses you incur due to their failure to maintain the road surface to an acceptable standard.
After all, it's become a national pasttime.
In fact, if frivolous lawsuits ceased tomorrow, there'd be an awful lot of jobless lawyers, and companies with bigger profit forecasts!
Originally Posted by dwest1023
If it were me, I would just take the car to the dealer and tell them is pulls to the left. Let them found out what the problem is. Don't feel bad about it either. Radley Acura damaged my bumper and if I had not seen it before I left the lot, guess what? Needless to say, I made them give a a brand new bumper.
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
do you go to the one in columbia pike?
Originally Posted by TSeXy_Grl
hi...
i bought my car at radley last year. good service so far. how did they damage the bumper? were you in for an oil change? i've been in 2 times (oil change and tire rotation).
Yes I go to the one on Columbia pike. I was there for an oil change. I will no longer be going there. I will just bring my own oil and filter and go to jiffy lube where I can stand there and watch my car. This is the only way I will not get scratches. Whatever you do, do not let them wash your car. They wash with sandpaper. If you do not believe me look at the cars on the lot they have washed. They ALL will have swirl marks in the paint. I never let them touch my car with anything!
If you read the fine print on the wheel/tire warranty- it covers defects in the making of the wheel. I tried to use my warranty on a curb rash, and the dealer said it only covers the wheel if it breaks, cracks, etc ( workmanship). That part of the warranty was skipped over by the salesman. Search and you will find how many of us were duped into buying the wheel warranty.
Yea a guy on my old prelude forum hit a manhole in his lowered 3rd get at about 40 and cracked his tranny. The manhole was stickin a good 3-4 inches off of the ground, he filed something with the city and got his money. Make sure you take pics with a ruler or some measuring tape, measuring the depth of the pothole.
BobbyGraham388
10-22-2015 05:05 PM
