HELP --De-badge Still showing ACURA and TSX
question for anyone who debadged
when looking at the rear of the car you can't see anything, it looks clean and free of anything there
but, if you look at the same area with a light reflecting you can still see the outline of TSX and ACURA...
do i have to keep rubbing the goo gone/emblem remover.....or will wax take this off ???
thanks
thanks
this may sound like a dumb question...
but, i've had the car since october 2004, i live in florida where the sun is slammin.....
there's no chance that the paint has faded in that area...........right ?????
CL9 ABP
A bit but i think its just the clearcoat. Go get mothers 3 stage wax.
its
1. oxdiation remove old wax
2. sealant and glaze
3. caranuba wax
Should be off. My acura and tsx faded after the first wax. After that I waxed it more and you can't even tell anymore.
its
3. caranuba wax
CLAY BAR WAS AWESOME !!!!!
i couldn't believe how easy it was.....
applied that lube that they give you and gently rub one out......came off perfectly
if i would have known it would have been that easy, i would have bought it from the beginning !!!!
Thanks for your help guys....
Someone stole "My Garage"
Originally Posted by S14 n Tsx
scratch remover + wax should do the trick as well.
Originally Posted by curls
Scratch remover is an abrasive. Clay bar is not. I prefer the non-abrasive method unless all else fails.
Originally Posted by jcbridges
Clay bar IS an abrasive!! You can get clay bar in varying levels of abrasiveness, but make no mistake it is an abrasive. That is why you should not use very often.
(from autogeek.net)
WHAT DOES A DETAILING CLAY BAR DO?
Detailihg Clay bars have the ability to grab the tiniest of debris and hold onto it as it glides across the paint. Used with the proper lubricant, Detailing clay bars are not abrasive and will not affect the paint surface with the exception of cleaning it. Anything that protrudes above the top coat surface will be grabbed by the clay bar and pulled out. The clay lubricant will prevent this debris from scratching the vehicle. Once clayed, the paint will feel remarkably smooth and have the shine that comes with perfectly clean
paint.
Originally Posted by jlukja
I don't think so.
I used to own a detailing company and have years of experience detailing cars, boats and even corporate jets. I have included this exceprt from www.autopia.org, of the foremost resources for detailing online:
Read the patents on detailing clay and they describe very clearly that it is a mixture of a clay base (polybutene) and various abrasives. The primary detailing clay patent (U.S. Patent No. 5,727,993) identifies three unique elements (claim 57) used in concert:
“A method of polishing a protrusion or stain from a surface comprising;
applying a plastic flexible tool to the surface, the plastic flexible tool comprising a plastic flexible material having mixed therewith an abrasive comprising grains from about 3 to 50 m in diameter and;
applying a force to the plastic flexible tool such that a polishing force per area is applied by the plastic flexible tool to a protrusion or stain on the surface, and such that the amount of force per area applied to the surface is less than the amount of force per area applied to the protrusion or stain.”
Detailing clay is an abrasive system. If not used properly, detailing clay can cause light surface marring. There’s no need to fear if you use proper lubrication.
Originally Posted by Savio
(from autogeek.net)
paint.
You still wanna throw tomatoes??
rockyboy
01-25-2016 06:00 PM
acura_dipset_tl
01-01-2016 03:02 PM
asahrts
09-04-2015 05:55 PM
