Grounding in the trunk
Old Jan 14, 2007 | 05:20 PM
tsx004's Avatar
Is there any easy locations where I can find a grounding location in the truck? I've looked around but didn't see anything easy to reach. Any info would be greatly appreciated. Thanks
Old Jan 14, 2007 | 07:45 PM
etarui's Avatar
I used one of the bolts that hold on the rear tail lights. Check under the plastic cover as if you were going to change the bulbs. Any bolt connected to the frame should work.
Good luck!
Old Jan 14, 2007 | 10:25 PM
Reach's Avatar
For my amp and electronics, I drilled a new hole in the spare tire well and fitted it with my own bolt.
Old Jan 15, 2007 | 01:27 AM
PhiSigBrotha's Avatar
for my amp install i used the bolt that holds down the ring for tieing down luggage.
Old Jan 15, 2007 | 05:21 AM
ILoveMyHonda's Avatar
17781708
I used one of the bolts that hold down the fold down seat.
emailnatec
29
Sep 28, 2018 04:27 PM
baelim
May 10, 2018 09:53 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
justin.w13.walker
Sep 22, 2015 02:21 PM
