Grounding in the trunk
Is there any easy locations where I can find a grounding location in the truck? I've looked around but didn't see anything easy to reach. Any info would be greatly appreciated. Thanks
I used one of the bolts that hold on the rear tail lights. Check under the plastic cover as if you were going to change the bulbs. Any bolt connected to the frame should work.
Good luck!
Good luck!
emailnatec
29
09-28-2018 04:27 PM
justin.w13.walker
09-22-2015 02:21 PM
