Gauge Cluster
Registered User
Gauge Cluster
does anyone know how to remove the gauge cluster on a 04 TSX?
from what it looks like there are 2 bolts under the cluster and possible 2 screws behind it.
has anyone done this before? i've taken tons of gauge clusters out of cars before, but these new acura ones i can't seem to figure out
Photography Nerd
Originally Posted by NightHawk CL9
where did u get the helms manual, i'm interested in getting it.
WAS HONDATAFIED IN
Originally Posted by Dan Martin
its not that hard
first you must remove all the panels under the steering wheel
after doing that u just unscrew two bolts from underneath the cluster (to the left and the right of the steering column) they are hard to see but if u look carefully ull find them
then just gently pull on the cluster towards you from the top
becarefull not to scratch any of the plastic as you pull out the cluster
hey but when u do the mile mod
doesnt your tranny still keep and active count of the actual milage
cant they check out the right milage through the tranny somehow ????
thats what i heard dont quote me on that one
Registered User
the reason i want to pull it out is not to change the mileage
i own a 03 CL-S and almost a year ago change all the gauges bulbs to LED's (used about 100 LEDs)to try and make it look like a TSX cluster, didn't look really good, and the LED's kept blowing out, so i want to open a TSX cluster to see how honda does it
I'd buy the tech manual before I pulled my dash apart to see how the magic works! That should give you all the electrical schematics/ratings and such for everything involved so you can duplicate it for your CL. If you want to be hands on... I'd check junk yards for a used cluster... that way you won't screw up your nice new cluster that works as new.
![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
The 2003-2004-2005 Accord has LED. That I know for sure. But the TSX cluster looks different. Also, has a different refresh rate.
Registered User
Originally Posted by 340HP
I'm fairly certain that the TSX has cold-cathode gauges, not LED. Could be wrong, but I think I'm right. I think.
brandnewcolony
09-12-2015 10:39 AM
