Front wheel drive...
Old Mar 27, 2007 | 01:21 AM
frenchv's Avatar
I'm coming from rear wheel drive, huh.. my TSX can go in a straight line if I let go of the steering wheel but sometimes it's veers all over the place. Especially on the freeway at high speed.
Is that normal or does the car need an alignment?
Old Mar 27, 2007 | 01:39 AM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
if its when you are getting on the throttle and when it shifts i could be torque steer. but if it does it when on Cruise control make sure you check your tire pressures.
Old Mar 27, 2007 | 01:50 AM
frenchv's Avatar
Thanks, I'll have to try that.
Old Mar 27, 2007 | 09:15 AM
jlukja's Avatar
The TSX is prone to follow the crown of the road and the tires like to tramline.
Old Mar 27, 2007 | 09:32 AM
CGTSX2004's Avatar
Check the tire pressures and then make sure the road you're driving on is not grooved in any way as the TSX is prone to tramlining, especially with wider wheels and tires.
Old Mar 27, 2007 | 09:40 AM
Still Water's Avatar
If you haven't done so already, google "tramlining" and you find the symptoms. The OEM Mich's really express this tendency on a variety of surfaces and road profiles. Monitoring your air pressure is a must do.
Old Mar 27, 2007 | 10:08 PM
vidgamer's Avatar
Mine doesn't do it so bad now. I think maybe they adjusted the alignment at the dealer, but I don't really know. But when I first got the car, it seemed a lot more "twitchy" on the highway, and one of the car magazines said the same thing.
Old Mar 27, 2007 | 11:17 PM
Marg_TSexy's Avatar
I too have noticed it's only very slightly "twitchy". But this only happens every once in a while at high speed on the freeway. But it's still not a GREAT feeling.
Old Mar 28, 2007 | 11:07 AM
frenchv's Avatar
I just did more road testing, it seems that the car goes straight for 5 to 10 seconds then either veers to the left or right.
Not sure if it's the way front wheel drive works, but I'll take it to the dealership in any case.
Old Mar 28, 2007 | 03:51 PM
waTSX's Avatar
Have camera, will travel
You're probably just used to it now. FWIW, it's not just the Michelins that tramline, the higher performance Pirelli's I just put on do, too. The tradeoff? Much better handling.
It really doesn't bother me at all.
Old Mar 28, 2007 | 10:39 PM
EuRTSX's Avatar
Yeah, I learned my lesson the first month I had the TSX last year in February. I wasn't aware of this "tramlining" especially because it didnt do that in my old car, but when I was driving, I wasn't firm onto holding the steering wheel, saw a VERY uneven road, and thought I'd be fine coming to a stop onto it, and when I went over it, my car steering wheel went absolutely nuts and veered into the next lane. Thank HOT there was no one there
Old Mar 28, 2007 | 11:06 PM
gr8fulted's Avatar
Good question, as I had wondered what the hell was going on when I drove on the interstate at 70 to 80 mph. The ride is smooth when applying the gas but the car gets a mind of its own when I let off the gas to coast. My solution thus far, as I bought my 06 NHB in January 07 is to ride the pedal and take advantage of the left lane.
Old Mar 28, 2007 | 11:14 PM
ChrismanTSX's Avatar
Registered Car Nut
If one played with the alignment, it may be possible to reduce the tramlining. I haven't tried that, but part of what makes the TSX handling great, makes the car more twitchy...
I'll take twitchy and responsive anytime... if I didn't want that, i'd drive a Buick
Old Mar 28, 2007 | 11:56 PM
1slowTSX's Avatar
It's not really a good idea to let go of your steering wheel while driving on the highway especially at high speeds.
Old Mar 29, 2007 | 07:36 AM
vidgamer's Avatar
And as far as going straight for a few seconds and curving, most roads are tilted, to allow for water runoff. That's enough to get a slight "pull" effect, or at least probably enough so that you can't let go and just have it go straight forever.
Old Mar 30, 2007 | 10:50 AM
frenchv's Avatar
I guess I was spoiled with rear wheel drive..
Old Mar 30, 2007 | 10:52 AM
Reach's Avatar
You can't read, can you? It has little to do with FWD/RWD, much more so with the tires, suspension, and alignment!
Old Mar 30, 2007 | 11:38 PM
Overtaxed's Avatar
It's not a weakness of FWD nor of the TSX. The TSX's steering is so sensitive and precise, this is why it will go towards the direction of the slant in the road.
Roads are slightly slanted on purpose, so water runs off. If you hit a patch of very even road, it will stay straight.
Old Mar 31, 2007 | 02:19 PM
vidgamer's Avatar
Yeah, I think RWD will still veer based on the road's tilt.... I wonder how much power steering differences also come into play.
Old Mar 31, 2007 | 10:40 PM
junktionfet's Avatar
It's silly to think that FWD won't somehow affect how the front end responds to the road, even while coasting. It is perfectly reasonable to say that if the TSX were RWD, the "tramlining" would be reduced by a very small margin while coasting and a much larger while accelerating.
Drive wheels aside, the rest of the thread is accurate--wheels and tires have a lot to do with it as well as the damping on the steering rack, etc.
Personally it doesn't bother me much except when braking hard on groovy roads.
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
08 NBP TL
Sep 8, 2015 08:49 PM
mtl_ilx
Sep 3, 2015 09:58 PM
nuldabz
Sep 3, 2015 05:49 PM
