Fog lights
Old May 31, 2011 | 10:30 PM
vidgamer's Avatar
Fog lights
OK, my cheap non-Acura fog light lenses have both cracked. Started small and got worse, which seems to me like it might be heat-related. I had some protective film on for a while, and it got too hot/burnt. So, I'm wondering if it would be better to have an HID conversion that has lower wattage?
I've read some comments about HID conversions and how inappropriate they are, but will it be that "different" in how it throws the light from the fog light? I can understand the problem with converting a headlight without a cut-off, but I'm wondering how offensive it is to convert the fogs, coz it sounds cool to me.
I've already ordered a replacement fog light set... thankfully I won't have to re-wire!
Old Jun 1, 2011 | 12:40 AM
mdkxtreme's Avatar
I've been using HID fogs with a protective film and have not experienced any burns. Also, my fogs have not cracked either. The film really helps
Old Jun 2, 2011 | 06:57 AM
vidgamer's Avatar
But does the HID conversion have too much glare? Is the cutoff adequate? I like the idea of having cooler lights and more light output, but not if it's too bright for other traffic.
Old Jun 2, 2011 | 11:38 AM
extracrunchie's Avatar
my factory fogs cracked, so i replaced the lense with lexan polycarbonate and applied laminx yellow film.
because of the winter here and a gapping hole, the reflector is tarnished, so i took some paint and repainted the housing
I got some DDM tuning HID 3000k (dont mind the dirtiness)
here are some night shots
As for glare, IMO its too low on the ground to blind anyone on they road.......it was only glaring when i pretty much looked at the fogs at eye level.
Old Jun 11, 2011 | 09:48 PM
Thermos's Avatar
Yay for DDM Tuning 3K
http://www.youtube.com/watch?v=yJLST9ley6E
Old Jun 16, 2011 | 10:19 PM
vidgamer's Avatar
Thanks for the responses. I dunno, I'd just as soon stick with normal halogens, if the fog housing wouldn't get hot and crack again. I went ahead and got replacement housings, though.
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
