Floor Mat Anchor
Old Oct 16, 2004 | 09:49 PM
danotto's Avatar
Floor Mat Anchor
Am I missing something, or is it nearly impossible to get the anchors through the 2 holes in the driver side floormat? I tried for at least 10 minutes and gave up in the end.
Old Oct 16, 2004 | 09:55 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Slide the seat all the way back and you'll be able to get the floormat on with no problem...
Old Oct 16, 2004 | 09:59 PM
blackjackman's Avatar
have problem with small holes too eh ?
Those clips are plastic, I think the first time I just push them thru by brute force then I got the knack.
Old Oct 16, 2004 | 10:45 PM
TSX 3Pedal's Avatar
Use all 3 Pedals at once
You have to bend the floor mat a little bit, try to slide the hole over the anchor at an angle...
Old Oct 16, 2004 | 11:55 PM
Panda_TSX's Avatar
weeee i just cannot get them into the rubber ones... but oh wells...
Old Oct 17, 2004 | 12:04 AM
TSX 3Pedal's Avatar
[danotto] Are you talking about the stock floormats or the all-season floormats?
I have both the stock and the all-season floor mats installed, they are stacked on top of each. All I have to do is slide the anchor into the hole at an angle...
Old Oct 17, 2004 | 02:21 AM
aaronng's Avatar
Driver/Detailer
How long do the fitted floormats last before the fibre is worn out by the heel of your shoes?
Old Oct 17, 2004 | 02:39 AM
CGTSX2004's Avatar
When I got the all-season mats, they took some maneuvering to get into the little pegs, but it couldn't have taken me more then a few minutes. Just gotta bend the mat a bit to fit.
Old Oct 17, 2004 | 04:47 AM
TSX 3Pedal's Avatar
I've had the all-season floor mats in my car since I've got it and I have a groove in the rubber right under my clutch, but it's not fully worn out.............yet
Old Oct 17, 2004 | 08:47 AM
Belzebutt's Avatar
I'm the Firestarter
Do you gus stack the winter ones on the summer ones?
In the Accord I used the winters alone, so that it wouldn't add thickness.
Old Oct 17, 2004 | 09:04 AM
o3jeff's Avatar
I stack the all season one on top of the summer one.
Old Oct 17, 2004 | 10:18 AM
CGTSX2004's Avatar
Not me. I took the summer ones out and they're sitting the in trunk right now.
Old Oct 17, 2004 | 12:36 PM
tony4311's Avatar
I am Ahab!
I take them out to. I use the rubber ones to keep the regular ones away from salt not to put it right under the salt.
baelim
May 10, 2018 09:53 AM
Jul 16, 2017 07:33 AM
JDM96specCTR
Oct 17, 2015 01:06 PM
