Find out your actual speed while moving! (nav only)
Old 03-03-2006 | 07:23 AM
  #41
sudhirn's Avatar
the first sentence of that thread states "a while ago there was a thread about finding out ur actual moving speed in the little climate control dash" ,thats what i am talking bout!!!
  #42
sudhirn's Avatar
not on the NAV screen
Old 03-03-2006 | 08:16 AM
  #43
Bass Mechanic's Avatar
guys, dont Question gpsiir, he is a GPS god ive personally met him and i know what he does for a living. i wont disclose it here but lets just say that if he says its this way or that way you can believe he knows what he is talking about.
you could say he does this for a living
note his name GPSiir
Old 03-03-2006 | 08:18 AM
  #44
Originally Posted by IlliNorge
This is mostly correct. However, you do not need more than 3 sats to fix a location in 3 dimensions, assuming that the sats are not all in the same plane. This also assumes that the navi software is aware of altitude changes on the ground. Otherwise, it would presuppose that you were floating on air.
I don't speak with TSX navi authority (yet), but I do speak with college physics knowledge.
if you even had a clue as to the background of the poster your talking about you wouldnt be posting anything.
you can be sure that gpsiir knows exactly what he is talking about.
Old 03-03-2006 | 09:35 AM
  #45
IlliNorge's Avatar
Benchwarmer
Ha! The chest-thumping begins! If you will carefully read all that I and gpsiir have said you will see that everything matches up in regard fixing on a point on the earth's surface. The ground receiver REQUIRES only 3 sats above the earth to fix a position on the ground. The fourth through the eighth sats provide greater accuracy. I'm sure gpsiir and I both know what we're talking about.
02-25-2020 09:57 AM
cycdaniel
12-17-2019 10:58 AM
dlevesque
09-16-2015 10:18 AM
PortlandRL
09-14-2015 12:01 PM
kuzdu
09-10-2015 08:42 PM
Quick Reply: Find out your actual speed while moving! (nav only)
